A/C - Is this the low side connector?
Is the low side connector in front of the radiator on the right (passenger) side? The connector is on the side of a canister with two wire connectors on top. I want to make sure before I test and fill and I can't find it listed in the manuals anywhere.
TIA!
TIA!
I wish it was! That would make things ALOT easier. Unfortunatly, the low side connector is on the other side of the radiator, under the rad hose. It's very difficult to get to without getting burned! I let the car cools first before I test/fill.
Jim
87 928 S4 a/t
87 951
Jim
87 928 S4 a/t
87 951
928 OB-Wan
John,
the low side is a PITA to get to... to fill the system properly it must be running
make sure you have CLEARANCE on your gauges/hoses PRIOR to starting the car
and whatever you do DON"T stick your hands down there while it's running... hands and fans don't mix
Electron Wrangler
All,
It does vary by year. On the GTS its in the bulkhead area, under the cover next to the windshield wiper motor - its a pain to have to remove (and particularly to reinstall the cover) - but no fans to worry about and relatively easy to reach.
Alan
Alan
Bringing it to life with photos...
This is where stuff is on my '90 S4:
Low side:
zoomed in a bit more:
High side:
You got that right, Jim. It took about an hour of this (blower on high) ...
... before I could get in there to detach the low side hose after charging my AC system about a month ago.
Low side:
High side:
Been there, done that. A better solution for the S4 low side is to buy one of these "PRO-SET" adapters..
with a cutoff valve, specify blue valve handle:
http://cgi.ebay.com/ebaymotors/Ball-...6266QQtcZphoto
Or this adapter:
http://cgi.ebay.com/ebaymotors/1-4-S...5847QQtcZphoto
The PRO-SET adapters are very low profile, so they fit nicely.
This is for the factory R12 fittings only. If your car has been converted to R134 the converted fittings may be even more of a interference problem.
If you look at this ebay seller's store, you'll find he has just about everything you could possibly need.
borland
S4, Slate Metallic
Or this adapter:
borland
S4, Slate Metallic
Also, with the adapter, you stand less of a chance of damaging the car's connection threads (aluminum).
This (damaged threads) can happen when your trying to thread the hose to the fitting and are struggling with a water hose interference (cross thread damage), or when removing the gage set hose from the car's fitting while under pressure.
Also, using an isolation valve on the high side, eliminates blowing oil when disconnecting the high side hose.
There is also a way to charge liquid directly into the high side with the engine OFF. Never ever try to charge from the high side with the engine and compressor running.
Dan
'91 928GT S/C 475hp/460lb.ft
