928 Forum 1978-1995
Sponsored by: 928 Specialists
Zero oil pressure....I get to have fun again
Old 08-22-2005, 12:51 PM
  #46
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
Originally Posted by Andrew Olson
You're one saddistic man!
Been said before.......
Old 08-22-2005, 12:57 PM
  #47
Big Dave
928 Engine Re-Re-Rebuild Specialist
Big Dave's Avatar
I'm still running scenarios through my head while I wait for the flywheel lock, and I keep concluding that a nut that backed off is the most likely scenario. I know I tightened it down, but I didn't have a locking tool to really crank down on it.
I've already been looking through the pics I took when I was doing the rebuild. The oil pump gear looks to be seated exactly the same before and after replacement, including at least the outside thick washer between the nut and the gear:
Before/After:
Old 08-22-2005, 01:05 PM
  #48
Chris
Chris's Avatar
It may be the angle but looks like the gear is sitting higher and is offset, I can't see the keyway in the 1st photo.
Chris
Old 08-22-2005, 01:06 PM
  #49
Kevin in Atlanta
Kevin in Atlanta's Avatar
Originally Posted by Sterling
My bet is that the gear nut backed off. It is really difficult if not impossible to get it set with to the proper torque without the special holding tool...
Is that really likely when there is a keyway involved? The pump gear would have to migrate quite a ways to get past it, right? Looking at the pictures the gear has not moved.
Old 08-22-2005, 01:15 PM
  #50
Big Dave
Big Dave's Avatar
These are pictures from before I changed the gear and after I replaced it. I don't have pictures of the gear as it is currently (since I can't get the center belt cover off yet).
The woodruff key wouldn't prevent the nut from backing off, but without the nut, the gear certainly could wobble it's way free and eventually get slanted on the spline as it looks to be now.
In the before/after pictures, it looks to me like the spline of the pump is equally flush with the nut. If I had a missing spacer, I would expect the nut to sit farther down on the spline, exposing a couple of threads.
Old 08-22-2005, 01:29 PM
  #51
Kevin in Atlanta
ok, I get it now.
Old 08-22-2005, 01:31 PM
  #52
Bill Ball
Under the Lift
Bill Ball's Avatar
Default Don't so what I said....
Dave:
You're smart to wait for the flywheel lock.
Received from Jim Bailey:
"that timing ring for the automatic is simply pressed on and as a result with enough force it may move spin and the ignition timing gets all ****ed up..... that has made more than one mechanic really really crazy after doing a t-belt water pump job and now the car runs really bad or pings or will not run at all. When we make a custom 5 speed flywheel and fit the S-4 auto timing wheel to a double disc 85-86 manual flywheel we spot weld the ring after we index it so it will not move,"
Ugh. I appreciate informed corrections. I did use that ring to undo and redo the flywheel bolts, but they are only about 60 ft lbs. I never did it for the crank bolt, so it was kind of stupid of me to post that. I recalled that it was pressed or shrunk on but thought it was firm enough to take a lot more torque.
Thanks again to Jim for stopping something stupid.
Old 08-22-2005, 03:27 PM
  #53
Big Dave
Big Dave's Avatar
Originally Posted by Bill Ball
Dave:
I wondered about that. I'm NOT going to blip the starter with a breaker bar on the crank, either. With the oil pump gear the way it is, I'd risk jumping the belt.
As much as I'd like to keep conjecturing about the situation, I'm stuck until I get the cover off. I'll check tonight to see if I can wiggle it free enough to get a closer look at the gear.
Has anyone gotten the center belt cover off with the pulleys still in place w/o breaking the cover?
Old 08-22-2005, 03:50 PM
  #54
worf928
worf928's Avatar
Received 1,638 Likes on 1,069 Posts
I've never been particularly interested in using that method either.
Yup. I don't remember exactly how I did it. But, the center cover came off and went back on without permanent deformation or damage.
Old 08-22-2005, 04:12 PM
  #55
Imo000
Captain Obvious
Super User
Imo000's Avatar
I've also pulled the center cover off my '85 withouht removing the balancer. Give it a try, it should come off.
Old 08-22-2005, 04:32 PM
  #56
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
Just reaffirming the above... the center plastic cover will come off w/out removing the crank pulley.
Old 08-22-2005, 04:42 PM
  #57
goliver
goliver's Avatar
Looks to me like it is just the nut coming loose and the gear wiggled itself off of the splines a bit.
Dave,
You deserve some luck buddy!!! Heres hoping that is all there is to it.
Regards,
Old 08-22-2005, 04:52 PM
  #58
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
just outta curiousity is there a shim behind the gear to help it maintain alignment or some sort of washer???
Old 08-22-2005, 04:56 PM
  #59
Big Dave
Big Dave's Avatar
Here's the PET diagram:
Old 08-22-2005, 05:32 PM
  #60
Mongo
Fuse 24 Assassin
Mongo's Avatar
thought so....thanks!
Hopefully you can get her back to normal by Friday Dave.
Quick Reply: Zero oil pressure....I get to have fun again
