re-use never run head gaskets??
never run in scot new euro engine. No heat at all, but torqued down to spec. any thoughts here?
they look good, but if they are compressed are they kind of gone??
MK
MK
Im more worried about the crushing of the rubber insert in the gasket deforming for any deformaties on the head or cylinder surfaces. I dont know, and we grenaded the motor the first time, and dont want there to be any issues the second. if it is a clear, no problem, like the main bearings (rods looked a little scarred for some reason), ill do it. otherwise, there is some more costs for poor scot!!
they look brand new though ! does that count? and again, absolutely no heat, just cranking down of the head nuts to spec in the three stages
MK
MK
Originally Posted by GlenL
I'd look them over and then re-use them. Not squished now any more than they will be later.
It's always a personal choice; I would do it. Isn't that like $150 worth of gaskets? Might be a small part of the total but those chunks add up.
I've always lived by the rule of thumb that a head gasket only gets installed once. You have to decide if it's worth the risk.... few $ for some gaskets vs another teardown and collateral damage potential.
I would buy a new one.
Composite head gaskets are not meant to be re-installed.
If you're using a shim, no problem, a fel pro type composite...buy a new one.
Hell, it's only money.
1.5 to 1 now. (M21 sniper even knew the brand name!)
leaning toward new ones! heck, its only scots money! but gosh, i just hate waste! these gaskets have seen no heat and look brand new!
MK
MK
Hell, it's only money.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Fleet of Foot
Ummm... it's just me, but piece of mind is worth a LOT more than saving a few bucks, as well as the chance that you would be pulling the heads TWICE in the event it doesn't work out. False economy, buy new ones
MK
MK
If you torqued it down and then removed the head, would you get new gaskets?
An engine builders trick to to re-torque the head multiple time to make sure the gasket is fully crushed and the studs are all at the same force. Seems like that's what oyu've got: a pre-crushed gasket. It's not bad to have lost "fresh springiness" as that's absolutely what you _don't_ want.
Captain Obvious
Super User
Super User
Canging it would be ideal. However in the past ,I had the same situation and did re use a head gasket. It wasn't my car(90 cavalier), so it didn't matter that much.
What you might want to to is, IF you re use the gaskets, first torque them to spec. and then just a little more, maybe 5% more. This way the gasket is more compressed than before. If you do this, the gasket will hold just like a new one would.
I always over torque the heads by a couple extra lbs. Gives me a bit more safety margin.
