928 Forum 1978-1995
Sponsored by: 928 Specialists
Lighted Door Sill Insignia Write-up
Old 08-14-2005, 04:33 PM
tv
tv's Avatar
Great Job Andrew!!
Old 08-14-2005, 04:37 PM
SharkSkin
SharkSkin's Avatar
Nice job... If I ever get tired of my Jager aluminum sill plate inserts I just might do this.
Old 08-14-2005, 04:55 PM
AO
Supercharged
AO's Avatar
Originally Posted by Randy V
Yeah, I understand. When I install mine I think I'll just stick it to the underside of the sill plate (with a couple pieces of new double-sided tape) and not worry about also sticking it to the door sill.
When you get back - tell me how you ran the wires from the carpet hole up to the door wire tunnel, and where did you set the small transformers.
Thanks.
Back now. THe EL strips came with the transformers, so that part is straight forward.
Wiring - You just have to be creative. You need to run some additional wire from the light, through the plastic tube and back to the EL strip. The wires are very thin, so you can put them under the carpet and you won't see them.
After fishing the wires from the light through the black plastic tube, I simply pulled the carpet on the inside of the fender back and snaked them through to the floorpan and then back to make your connections. On the diver's side I was abe to stick the transformer under the seat - It's about a 1" cube. On the passenger side I put it under the amp cover. It's one of those thngs that become very apperant once you get there. You know you have to connect the wires, so you just do it.
Follow up note: I just noticed the my driver side is flickering when I open the door. Not sure if it's the switch, my wiring or the transformer. Pass side is good. Comes on instantly. Will update ASAP.
Old 08-14-2005, 05:24 PM
SharkSkin
SharkSkin's Avatar
Just turn the switch pin back and forth so the contact surfaces rub. If this alters the flickering, clean/replace it. They're cheap.
Old 08-14-2005, 05:42 PM
bfellows
bfellows's Avatar
No shipping outside of the US!!!!! Is it something I said........
Old 08-15-2005, 09:27 AM
AO
Supercharged
AO's Avatar
Flickering is gone. Pretty sure it was the switch. I'll put it on my list of parts to order next time.
Old 08-15-2005, 11:24 AM
ROG100
Basic Sponsor
ROG100's Avatar
Bert,
I can buy for you and send to the UK if that helps.
We Brits have got to stick together!!!
Old 08-15-2005, 12:26 PM
NickT
NickT's Avatar
Here Here!
(Born in Kent, grew up in Sussex)
Old 08-15-2005, 01:47 PM
Flint
Flint's Avatar
You know, this has started the little wheels (in the head) moving about other places that this could be applied. One I was thinking of (though I haven't been in there) is under the shift plate for automatics to light up the letters (PRND32).
Old 08-15-2005, 02:11 PM
Champagne
Former Vendor
Champagne's Avatar
I've put in an order for the 1.5" wide strips.
I emailed the seller to make sure they were indeed that width but he as not replied yet.
I will update with new information when I get it.
Paul
Old 08-15-2005, 02:22 PM
Alan
Electron Wrangler
Alan's Avatar
Flint,
Thats actually been discussed before....
https://rennlist.com/forums/showthre...eferrerid=6055
Alan
Old 08-15-2005, 02:23 PM
Champagne
Former Vendor
Champagne's Avatar
Hey all,
I just received a response from the seller on eBay:
"Hi Paul, Thank you for your purchase - I thought I had answered. sorry. These strips are 1.25" iluminated - with the lamanination they are 1.5 but only 1.25 illuminated - if this will not work for you I will be happy to refund you money."
I ordered them anyway as I'm satisfied with Andrew's results. Hope mine turn out as good.
Paul
Old 08-15-2005, 02:28 PM
bfellows
bfellows's Avatar
Andrew + Roger,
Many thanks for the kind offer to forward these on. I'll be in touch when i've decided on the color (probably the weekend........heavy workload at the moment) I'm favouring the blue at the moment to match the LED on the Clifford alarm i have fitted.
If my memory serves me correct i'm sure you can retrofit the shift light illumination from earlier models. Brackets are already in place for the bulb etc.
Old 08-15-2005, 02:32 PM
AO
Supercharged
AO's Avatar
Originally Posted by Champagne
Hey all,
Paul
You just need to be maticulous in placement. You'll be your worst critic. However, I may have identified another source for these strips in a wider variety of colors. Just need to call and confirm pricing/sizes. Will update as soon as I speak with them.
Old 08-15-2005, 10:52 PM
steaditim
steaditim's Avatar
Hey Guys:
I'd love to pick a set of these up, but I'm in Toronto. Anyone willing to order and ship on my behalf. I'll send the cash ahead of time.
Thanks,
Tim
Quick Reply: Lighted Door Sill Insignia Write-up
