85-86 Ground Points??
I do not have a diagram that I can share easily but let me see if I can list the ones I found went through on my '85:
Battery negative to chassis-
Right side, rear, behind tool sover - one connection for several brown wires to chassis
Fuse relay panel area - above panel - two locations - several brwon wires to chassis
Bottom of engine on right side to right side chassis - heavy gage black wire
Top of engine on right side to right side chassis near/behind battery jumping post
Left side in front of radiator - one location for several brown wires to chassis
Right side in front of radiator - one location for several brown wires to chassis
Rear of engine, right side, below air cleaner and fuel distribution system
I hope this helps.
I hope this helps.
I'm looking for something similar for my 86.5. I have a right tail light issue with a ground that has killed it. I can't seem to track back the ground or figure out what the problem is. If anyone wants to sketch one out, I can make a digital diagram of it and post it for everyone.
