928 Forum 1978-1995
Sponsored by: 928 Specialists
HELP!!! '83 US AUTO RUNNING POORLY!!
Old 08-21-2005, 10:28 PM
derekescott
derekescott's Avatar
got it, i always referred to that as the "spinner-doodle-toothed-thang"!!! LOL!
I am setting an appointment for this week.
Old 08-22-2005, 02:27 AM
jpitman2
jpitman2's Avatar
Do you have a rodent snuk up the exhaust? He'd scream when you goose the throttle! So would I...
jp 83 Euro S AT 49k
Old 08-23-2005, 11:44 PM
derekescott
well, I replaced everything from the CAT back.....if he's there...he's burnt fauna!!!! I'm thinking of vacuum/gasket leakage!!!!
Old 08-24-2005, 11:24 AM
Rick3452
Rick3452's Avatar
DEREK, Please report back with the "end rusult". Thanks, good luck.... Rick
Old 08-31-2005, 08:22 AM
derekescott
Guys: Well I finally bit the bullet and put "Ruby" in the shop....evry instake gasket/seal was leaking. This is what happens when a car sits for a while and then you do what you're supposed to do "drive it"...wil post when I get her back
Old 08-31-2005, 02:30 PM
...P
...P's Avatar
The shriek is undoubtedly due to a loose belt. Check tension by gently pushing on them and it should be apparent which one is loose. Run the car up on secure (safety first) lifts, and you will see each belt has it's own built in adjustment. The Germans used two or three nuts and bolts to do this for each belt, and it's pretty intuitive. Turn the adjustments a few notches and you'll see the belt get tighter or looser. Don't overtighten, as this leads to bearing wear.
As for the drivability issue, based on what I see in the initial post (I also have a '83 a few serial numbers down the assy line from M21Sinper) I would check the fuel filter, Thermo Time Switch, and the Temp II sensor. If any of those have not been changed out on a 22 year old car, you probably should go ahead and change em out now. My 83 had a coughing spell when I started and goosed it a while back, and it was the TTS, which works with the cold start valve.
These are just my hunches, hope this helps lead to a solution,
Regards, P
Old 08-31-2005, 03:03 PM
m21sniper
m21sniper's Avatar
Hey P, good to see ya here bro.
Old 09-12-2005, 12:30 AM
derekescott
Sniper: What do you know about torque tubes/auto trannies/torque converters?
Old 09-12-2005, 02:43 AM
m21sniper
m21sniper's Avatar
Not as much as some, a lot more than some others.
LOL...what do you need to know? I'm sure someone here will be able to help.
Quick Reply: HELP!!! '83 US AUTO RUNNING POORLY!!
