IT LIVES!!!!!!!!!!!!!!!!!!
Originally Posted by UKKid35
Have you tried adjusting the CO idle mixture using the pot above the fuse panel?
Scott,
Your car is cat equipped, it doesn't have the pot above the fuel panel.....
Give the car a good Italian tune up with some nice fresh fuel in the tank. Then see how it's running.
The MAF may be a problem, but it might be something else.... How many miles on the car ?
Regards
Regards
Originally Posted by John Speake
Scott,
Regards
Regards
I will freshen up the fuel, fire her up again and run around the neighborhood see if he just needs to "cough up a few things" and feel better.
I fired the Yeti up at 6 pm last night (not 10 pm) so I could "blow her out" without getting lynched by the neighbors. After a few good, hard revs and idling for about 10 min. the fuel mixture, idle and small back fires cleared up. She sounds like the beast of old!
I still need to re-bleed the entire hydraulic system again to clean up the clutch and brake issue before I can take her for a spin around the block. The clutch is so bad I can't even put it in and out of gear and the brakes.
