360HP motor for sale
Administrator - "Tyson"
I tried to trade Lorelei for a GTS earlier this year and got my head bitten off (not by Lorelei). So I'm guessing trading for a motor would be just as bad?
John....would that motor you have for sale drop into my 87 auto?.....i've either got rod bearing material in my oil filter or thrust bearing problems....not sure yet but if the block is pooched, your engine sounds interesting.
John Trainor
87 euro auto
silver/black
John Trainor
87 euro auto
silver/black
that sounds interesting, but i think retrofiting the "U" to the Ljet type , getting rid of the CIS, and then using the MAF from your 87 word work. the only issue would be (and there would still be a lot of them , would be injectors, but maybe you could fit those in the US euro runners. wow, lots of differnces.
nahhhh, just pull it and fix it.
MK
MK
John Trainor
87 euro auto
silver/black
John Trainor
87 euro auto
silver/black
MK
MK
I wouldn't do it.
Get a used short block, change the bearings, swap the heads/intake and drive on
1 Post
HI,
Is that the correct dyno link ????
My UK spec 4.7 S2 was on a dyno last Sunday and got more bhp than that graph ???
All the best Brett
928 S2 AUTO V8 4.7 LTR 1986 IRIS METALLIC BLUE WITH PROMAX CHIPS, RMB, KICKDOWN SWITCH.
All the best Brett
The dyno chart is a corrected rear wheel HP on a dynojet.
You UK spec. 4.7 S2 was 310 crankshaft hp. If your getting a 310HP rear wheel number, then it is far from stock.
1 Post
Hi,
My rwhp was 284.6 corrected by 7% to 306 at CRANK.(auto)
I still dont quite see how you get 360 bhp from 305 rwhp ?? Are you saying you have a 55 bhp transmission loss, between Crank and wheels ? Is this a manual or auto ?
Or do american dynos work differently ?
All the best Brett
All the best Brett
360hp X .85= 306HP
It is very common to use a 15% lost from a manual drivetrain to get to the crank hp rating. Some use 18-20% for the auto cars.
