928 Forum 1978-1995
Sponsored by: 928 Specialists
Ground Wire?- Pic
Old Aug 6, 2005 | 06:26 PM
GR-JON's Avatar
GR-JON
Default Ground Wire?- Pic
Hello, I was going around cleaning ground points and ran across a black ground wire which bolts from the back of the driver's side timing belt cover to the coil bracket. I started to disconnect it and it broke in half. Can someone confirm that this is just a ground?
File Type: jpg
Old Aug 6, 2005 | 08:20 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
I've noticed last night that the passanger side ground wire (same as in pic) is completly disconnected. My car runs great withouht it. Give it a try and start the engine. If it runds good drive it, and order a replacement. Install it when it arrives.
Old Aug 6, 2005 | 08:30 PM
GR-JON's Avatar
GR-JON
Thanks. I'm in a no-start situation and cleaning all ground points is what I'm doing now. When the car was running, I believe this wire was already broken. It just fell apart when I took it loose. I'll get a replacement and install it anyway.
Old Aug 6, 2005 | 10:29 PM
worf928's Avatar
worf928
That's the ground for the driver's side coil. The passenger side coil ground attaches at the passenger side engine lift loop (which is mounted to the top-most part of the block, outboard at the front.)
Old Aug 7, 2005 | 03:57 AM
the flyin' scotsman's Avatar
the flyin' scotsman
The wire is indeed a ground from the coil to the engine............while the coil is static the running engine, especially with new mounts is in motion hence the stress and strain on the wires.
Easy replacement.
Old Aug 7, 2005 | 05:25 AM
SharkSkin's Avatar
SharkSkin
No such thing as "just a ground" on a shark....
Old Aug 7, 2005 | 05:49 AM
Garth S's Avatar
Garth S
Yes ... the complete phrase too often heard is " Screwed again .. by just a ground!"
There are more ground connections that one wants to count - and despite a certain redundancy, any one of these can let you down. You can order a replacement - but for pennies, that one can be repaired or replaced with a piece of wire and crimp on connectors.
Old Aug 7, 2005 | 08:40 AM
Daniel Dudley's Avatar
Daniel Dudley
Radio Shack or Auto Zone
Old Aug 7, 2005 | 11:24 AM
GR-JON's Avatar
GR-JON
Yeah..."just a ground" is certainly an understatement! I'm checking and cleaning ALL grounds and this one is an easy replacement. I'm on the way to autozone and get some wire, connectors and a good crimper. Hopefully I'll uncover my no-start problem.
Old Jul 18, 2006 | 01:38 AM
kraabel's Avatar
kraabel
is there a part number for this ground wire? or a place to easily find a replacement the same length. I thought about cutting it and putting a new end on, but it looks like it might be a touch short then.
Old Jul 18, 2006 | 01:47 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Hi while yor at it check the other side if you have a 32 valve, sometimes both wires fail then mysterious thing start happening to the engine running condition
Old Jul 18, 2006 | 02:00 AM
kraabel's Avatar
kraabel
Mine is an issue with the circle head breaking off somwhere along the way. The wire seems fine.
