Stereo Replacement-The basics!
I've got an 88 S4 with original radio / cassette stereo and after a year of crap reception I bought a new head unit and ariel.
I've replaced the ariel and ariel wire to head unit and then removed the existing head unit to discover the ancient 9 pin connector at the back- now maybe that just highlights my total ignorance or incompetence as the new unit comes with block connectors and I figured I'd just hard wire it, the million dollar question(s) is HOW?
I reckon I could figure out the constant live, ignition and earth- it's the speakers that get me, coupled with the amplifier.
Has anyone already figured out the nine pin speaker connection configeration- what colours go to front left etc. etc. or do I wire in at the amplifier?
I've searched the threads and you guys are on a totally different playing field- any chance someone could explain it to the cave man?
algie928s4 Wrote "I've got an 88 S4 with original radio / cassette stereo and after a year of crap reception I bought a new head unit and ariel.
I've replaced the ariel and ariel wire to head unit "
First, get Prospero to tell Ariel to get it together.
Second, stop letting Caliban help in the garage. ;-)
All of the speaker wires are located next to the amp, which is located on the right hand side of the passenger seat. I would guess that the new head unit is more powerful than the amp, so I plan on bypassing the amp and running new speaker wires to the head unit. One thing that I have discovered is Blaupuntk used 2 olm speakers and everything today is 4 olms. So I plan on replacing the speakers as well.
I would try on the web to look up the original radio head unit user manual or wiring colours - my 83 came with head unit manual so I am okay here when i decide to replace it. An email to maker of head unit might get a response, or at least tell you their std colours? In my experience, most speaker leads are colour with black trace is a ground, colour is a +ve lead; l-r and f-r colours varied in the past - commonly grey, green etc, not primary colours, these days they tend to standardized - column B of this page http://www.geocities.com/svxdc/Legacy-pinout.htm shows std colours now.
You can find which leads go to which speakers with a dry battery - take each pair of speaker wires and put one on -ve, wipe other over positive - this will usually give you an audible scratchy sound from a speaker connected.
jp 83 Euro S AT 49k
jp 83 Euro S AT 49k
Received 1,623 Likes
The WSM has wiring diagrams for the stereo.
My page on the install for my '91 http://members.rennlist.com/worf928/91si.html has a wiring diagram with the pin-outs for the DIN connector. The factory system uses a single ground wire and the factory harness has 6 conductors only. I built a harness adaptor to use the DIN connector and ran two extra wires to the amp location for the fourth speaker.
