High Flow Injectors L-Jet
Minor update on this...the D-Jetronic was used on the 1.7L 914 and had a higher flow rate than the L-Jet units from all ymm.
http://users.erols.com/srweiss/tableifc.htm
Very useful table of data, except that 928 injectors are conspicuously absent. Somebody e-mail this guy with the info please!
Man of many SIGs
For those looking for higher flowing, barb style, low impedence injectors. Use Bosch 0 280 150 151 They are 29 lb/hr I installed them in an L-Jet equiped car and the idle is normal and the L-Jet has no problem pulling enough pulse duration to keep the A/F ratios in line.
Won't those be really rich when the Ljet is running open loop out of the map ignoring the O2?
I don't think there is any issue running high impedance injectors when the originals are low impedance, you just can't go the other way low impedance into a high impedance system.
Man of many SIGs
FWIW this is a common issue on 88-89 turbo Z cars. The OEM injectors are 259cc low impedence injectors but the Jim Wolf aftermarket ECUs support high impedence 420cc injecotrs from 70s era Mercedes S-cars. The fix for Z cars is to wire in 10 watt, 6.8 ohm dropping resistors to the harness.
It looks like you may have found other options to source low impedence, high flow injectors, but this is pretty common in the Nissan world.
Man of many SIGs
