ABS light on, Speedo, odo, trip not working.... (FIXED)
The noise from the right rear was in fact a bad outer CV joint.
When I took the car for a test ride I noticed the speedo wasn't working. Additionally, the odometer, trip odometer and other digital display items especially the outside temp reading is all messed up. The display is still there and the odo reads 54046 and didn't change in the 2 mile trip to put gas in the car. I noticed it after filling the tank up and I went to set the trip to zero the mileage hadn't changed. Upon pulling out of the gas station I notice the needle on the speedo wasn't moving. Tach works, fuel gauge seems to work (although it didn't go all the way to the full mark), temp gauge appears to be working as does the oil pressure gauge.
Any ideas?
Any ideas?
Fleet of Foot
I'll bet the interior lights don't work either... Check fuse #24 (I believe) and see if it's blown. If so, you may have a short in the interior light circuitry... what fun!
Originally Posted by shaaark89
had a similar thing happen on my '89 when the kickdown fuse blew.
Owns the Streets
Needs Camber
Needs Camber
ABS light on?
Mine comes on after car is rolling. DR advised at SITM that if
ABS light comes on after startup, then it may be the ABS relay.
If light engages after it detects signal error (as in car rolling), then it's one
of the ABS sensors or loose connection at those plastic-can connectors.
The front sensors on the S4 were held on by 10mm? hex bolt.
Ernest (NYC)
Ernest (NYC)
Chuck, I'm guessing that it is your GTS (you didn't state which of your fleet). The newer cars get the speed pulses for the speedo/odo from the front right wheel speed sensor/tone ring. Also, if the ABS misses speed pulses from one of the sensors it triggers the fault light.
My guess is you have a bad connection, broken wire, defective sensor, or sensor with magnetic filings covering too much of the tip, or tone rings filled with crud. Start with checking all the connections on the front right and then move to the others.
I never got near the right front sensor. Would a damaged left rear sensor cause the speedo, odo and abs light to come on?
CZ;
My 93 5 spd did the same thing (for about 3 miles) upon first drive this year. Problem self corrected. Spanner tool didn't show faults (but I think the spanner is faulty itself...).
If you hit on a cure, let me know.
Scott
Scott
In 1992, the speedometer/odometer signal pickup was changed from the left front wheel to the left rear wheel.
If you are lucky, the sensor connection is faulty. If you are unlucky, the sensor is toast.
A repair kit is available if the sensor harness is damaged.
BTW, I get a fault warning for PSD or ABS (can't remember which, I'll check) when I start the car.
Based on your comment about the fuel gage not going to full, that could very likely be the ignition switch.
Next time you take it for a ride and the speedo doesn't work, try jiggling the ignition key while you drive down the road.
Do the head lights fail to come up when the speedo doesn't work?
borland
90' S4, Slate Metallic
borland
borland
borland
Have a feeling Wally is on to the problem though as I was just working in that area.
Stupid, stupid me! Everything works again. Seems I didn't plug the ABS sensor wire in tight enough! Hey, I'm a rookie at this and allowed to make stupid mistakes like this one. Guess the faulty outside temp gauge reading is not related. Oh well, something else to look into. I did have the drivers mirror off so I'm sure something needs to be looked at here.
I did notice I have a sticky temp gauge though. Noticed it was showing a very low temp after driving for a while so I tapped on the pod and it moved up to where it should have been. Any fix for that..........?
By the time Chuck gets done with his fleet, he'll know the 928 from initial old boy to late GTS. Quite a span.
