Brake bleeding?
Brake bleeding?
I just read "Pagid pads (OEM) mushy?" and had a few questions. I have not gotten into mine yet, but changing the brake fluid and 20 year old brake lines is high on the list for my 85S.
Q 1? Bleed the master cyl? Never heard of such a thing on my 911 SC. Where and how do you do it?
Q 2? Nobody mentioned depressing the brake pedal a inch or two while bleeding. Isn't there a check valve in the system?
Just replaced mine last weekend with a mighty vac (which is something I wouldn't recommend or do again). You can draw out the old fluid through the bleeder valves until you see the clean new fluid. In the end I had my kid pump the brakes. Try the mototive(sp?) speed bleeder everyone raves about it and it's pretty cheap.
I usually operate the brake with my hand while I peer under the car at the corner I'm bleeding. Long hose from bleed screw down into clear jar full of clean brake fluid. When the bubbles stop coming out... you're done. May require a couple pump-up the pressure stints with the bleeder closed between bubble releases. Don't forget to top off master cylinder as you go.
Mike
84 S
78 OB
Mike
84 S
78 OB
Get the Motive Bleeder. Poour the new fluid into the bleeder, screw the other end onto the res. and pump it up. Crack the pass. rear bleed nipple untill the fluid changes color. then do the same on the inside nipple (of the brembo's). Then to the dr. side. then pass. front out/in. Clutch slave nipple (-spd cars). dr. front. And lastly crack the nipple on the master cylinder. It helps to take a Turkey baster to suck the old fluid from the res. first. Took me 1/2 hour to bleed it all myself. and that was with changing the Clutch Slave Cylinder WHILE BLEEDING (NOT RECOMMENDED).
I will never do any bleeding job again without the Motive Bleeder. I think the tool is something like $60 and it can save you a whole day or more of frustration and mess. I think 928 spec. has them.
1)The master cylinder has a bleed nipple on my car........YMMV
2)Depressing the brake pedal is not required at all when using the Motive Power Bleeder
I got my Motive from 928 Specialists, not that expensive
Just checked the 928 Specialists site..........Motive Power Bleeder on sale $39
Gee.... nobody answered my two questions.
BTW.......Pagid pads are good (factory supplied in some cases) but produce a lot of dust and chew up rotors pretty quickly. You might want to investigate Mintex or MetalMaster pads (both the same I believe). They hardly dust at all, are usually cheaper, won't chew up the rotors as much, and stop just as well.
Originally Posted by TeufelHei
$39 plus S/H and worth every penny. Thanks Jeanie!
I'm going to be replacing my brake master cylinder to make it a bit more interesting.
Oldtee, Hinchcliffe answered your master cylinder question.
I'm not quite sure what you mean with your brake depressing question (I haven't read the Pagid thread). When you are pedal bleeding, you do not push the peddle past where you normally would because you risk tearing the master cylinder seal on corrosion. By check valve, are you refering to speed bleeders?
