Bosch Hammer Replacements May Be Available
Basic Sponsor
So far has worked fine on three GTS's, 2x89S4, 89GT,90GT.
Some issues with Ernies 91GT, however that could be the car or the unit.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Originally Posted by Bill Ball
Yes, the Spanner is in my toolchest and has been quite useful to me and other 928s in the area.
Originally Posted by Hughett
I've heard that some Porsche specialty shops now have a new scan tool that replicates the Bosch hammer. Apparently it uses interchangable software cartridges...and it's not cheap, but not as expensive as the Hammer (but more versatile).
My wrench recently acquired a new diag device - can't recall the name - but does EVERYTHING the Sys Tester 2 does - except reset newer door and alarm codes - it was around $4k!
None of this thread applies to me, tho.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Hi Rixter,
The Spanner does work on MY88 with the correct 12 way lead which I can supply.(Also owrks with MY 87 when upgraded EPROMs are fitted to LH and EZK ECUs
Regards
Regards
928 OB-Wan
Originally Posted by John Speake
Hi Rixter,
Regards
Regards
though we tried it at SITM with a special connector the gent had and it didn't power up... not sure if that was an issue with the spanner or connector (the hammer powered right up on the 88 and gave me the info I was looking for)
Originally Posted by ROG100
Harvey,
Whats wrong with the "Spanner" ????
THX HK 94 GTS Houston area
Hi Rixter,
If there was no display at all on the Spanner, then it sounds like a lead is off +12v unswitched, or a fuse out.
The Hammer works on just ignition switched +12v. The Spanner uses both +12v unswitched and +12v switched.
Plenty of guys with MY88 cars have used the Spanner without problems. :-)
Regards
Regards
Herman,
If you're going to be in Houston, let me know and you can borrow my Spanner. I'm in the Heights.
Originally Posted by Herman K
I recently aquired a hammer from John. I want to resolve an airbag issue I have on my GTS. I have come to the stage where I would like to hook up the hammer to another car besides mine and like to use your spanner to compare it's read out on my GTS. I'm working with Alan's guide for the FWM wiring guide to break out the circuits of interest to me at this time. can you let me know if at some point and time you would be available to run some test. You can send me a PM or e-mail and we can exchange phone numbers.
Herman,
You are welcome to try out my Spanner, however I am in the DFW area.
You can also hook up the Hammer on my GTS.
Roger
Roger
Thx HK 94 GTS
Originally Posted by MBMB
Herman,
Thx HK 94 GTS
