H4 headlights = 2 left shoes?
Someone should have picture of Euro car online to solve this. If not Netherlands is going to be full of them this coming weekend. Perhaps LHD and RHD side by side.
Supercharged
Originally Posted by Hacker-Pschorr
Andrew - where did you get these?
Well now, hold on there... as I said, I need to re-check to see the orientation. I don't want to name names until I'm sure of what I've got. I'll try and get a pic tonight when I get home, but I'll be helping BigDave re-install his engine so we can drive together to SITM. That for more important than my H4 issue right now. I'll post pics as soon as I have a chance.
Andrew: Get them focused correctly. A blind driver is dangerous. He has a 50% chance of choosing to err in your direction. If I had to choose between a guard rail that doesn't have insurance and a car that does, I might choose to err on the side of the one I have reason to believe has insurance. It's a jungle out there.
Gluteus Maximus
If I recall correctly, seeing Jon Holdsworth's RHD SE, there was some kind of sticker applied to the H4 light in the same shape.
Originally Posted by SharkSkin
Take a look at the attached pic. The wedge that you see to the right of the "4" in "H4" is what throws the beam upward on the right side of the road for use on RHD roads(US). If that wedge is on the other side, the lenses are designed for LHD roads.
Here's a couple instructions for aiming the headlights (courtesy Nichol's site):
http://www.nichols.nu/tip793.htm
http://www.nichols.nu/tip314.htm
Under the Lift
I got my H4's off a car in Italy. The rising wedge on both headlamps is to the right. The pattern is refered to as E-code. I use the method Rich Andrade described for aiming. This results in a beam that is below hoizontal and will not blind oncoming traffic. I see many people who think lighting up the treetops is good. With H4's you see the road, and unlike DOT lamps, the tree tops should be in darkness. Here is my write-up of installing the lamps.
http://www.billsworkshop.com/P928S4/h5toh4/h5toh4.htm
Andrew it is also possible that the bulbs might be the 80-100 watt which makes the "low beam" a bit bright. Some of the bulbs are 55-60 watt any standard H-4 bulb fits.
Originally Posted by jpitman2
I thought it was the CAR that was LHD or RHD, NOT the road! It relates to the driver seat position, not which side of the road you drive on doesnt it? UK, Oz, NZ etc are RHD countries, who drive on the LHS of the road!!!
jp 83 Euro S AT 49k, RHD
Andrew, your diagram is correct.
Originally Posted by sublimate
So you'd choose hitting something at a closing speed of 140mph over hitting something at 70mph? And double the speed = 4 times the energy!
Another unstated point in my original post is that we sit lower and may have the perception that we need brighter lights to compete with those beams higher than us. Where does this end, with two blinded drivers closing upon each other? I've given the H4s a lot of thought, but I vote for not running "off road only" rated lamps. Maybe having bigger amunition is the only answer.
Under the Lift
I use 80/100 H4 bulbs - sold as "off-road only". Properly aimed you should not get any oncoming drivers angry. The top knife edge of the H4 bulb and reflector should keep the beam down with the exception of when you go over a rise in the road or perhaps load the hatch with bags of cement.
Supercharged
I found some 100/130 H4 bulbs, but I'm afraid that using them might allow some of the smoke out of the wiring harness.
And everyone knows how hard it is to put the smoke back in once it gets out!
