928 Forum 1978-1995
Sponsored by: 928 Specialists
Electric Headlight Adjusters
Old May 2, 2005 | 06:27 AM
UKKid35's Avatar
UKKid35
Question Electric Headlight Adjusters
The early cars had hydraulic adjusters fitted that always seemed to be faulty. The later cars had electric adjutsers, so I've bought a used pair (which are yet to arrive) and was wondering about the control circuitry needed. Can anyone help or suggest what I might need. I probably won't fit the control in the cabin to start with, under hood would be fine.
Old May 2, 2005 | 07:04 AM
Vilhuer's Avatar
Vilhuer
Control **** beside drivers seat and some wiring, think that's all there is to it. It's very simple system.
Old May 2, 2005 | 09:31 AM
UKKid35's Avatar
UKKid35
The loom to the headlamps appears to incorporate the adjuster wiring in the later cars, I won't be able fit this in my car, so I will need to create something in its place, I'm just not sure what it will need.
Old May 2, 2005 | 09:42 AM
Cameron's Avatar
Cameron
Check the little plastic sockets on the headlight mounting bracket where the plunger from the electric adjustor motor connects to the headlight assembly. You need some small plastic clips to hold the ball in place in the plastic socket or the plunger will just pull itself out of the socket when you try to adjust the beam. I am working through this on mine.
Old May 2, 2005 | 11:15 AM
Alan's Avatar
Alan
Electron Wrangler
Paul,
Both headlight adjusters are connected directly together. Wire colo(u)rs should be RE/YE, GN/YE, BR/RE. Connect all same colors together.
You need to use the Porsche Potentiometer control for the other end - regardless of where you fit it. This also connects to exact same colors (should match). Also BR/RE connects directly to Ground (chassis if needed)
The RE/YE also connects to side lights positive (+12v when on) in the schematics so the aimers motors only work when the lights are on, should be your plan too - although any +12v fused ( and on with ignition only) would actually work OK here if that is problematic.
I'd suggest you wire it to the seat side position as intended and figure out the wiring - I don't see the point of remote aimers if you have to get out & raise the hood, besides a correctly located install will be more valued if/when you ever sell...
Alan
Old May 2, 2005 | 01:23 PM
Jim bailey - 928 International's Avatar
I seem to recall that the "swivel frame" 928 750 243 04 becomes 05 that is the big painted base of the headlight assembly and it was modified for clearance for the headlight adjuster motors.
Old May 2, 2005 | 03:39 PM
Bill 86.5 928s's Avatar
Bill 86.5 928s
I'm curious gents...what model year did they introduce electric adjusters? Would my 86.5 be electric? I don't seem to see any differences when I change the floor **** position.........tnx
Old May 2, 2005 | 09:45 PM
Alan's Avatar
Alan
Electron Wrangler
Bill,
I think it was 89 and on, you probably have the non-functional hydraulic version... BTW this was only on Euro... a big no-no in the USA due to stupid DOT requirements.
Alan
Old May 2, 2005 | 09:52 PM
justin's Avatar
justin
Yea I would love to fit these on my 80 US car....
Old May 2, 2005 | 11:05 PM
Red UFO's Avatar
Red UFO
I've been thinking about doing this on my Euro.
I got the ****, what else do I need just the hydralic line? Or can I upgrade to electric? Somebody here posted a link to some ebay add selling one of these a while back.
Old May 2, 2005 | 11:06 PM
Red UFO's Avatar
Red UFO
I don't see why you can't.
Old May 3, 2005 | 01:27 AM
Alan's Avatar
Alan
Electron Wrangler
Bill,
Check this out http://www.928.org.uk/mambo/content/view/68/43
Alan
Old May 3, 2005 | 04:05 PM
Red UFO's Avatar
Red UFO
Where do you Euro guys buy that stuff?
Old May 3, 2005 | 05:03 PM
Vilhuer's Avatar
Vilhuer
New parts directly from Porsche factory customer center or from here for example:
http://www.m-freisinger.de
Used, there aren't many possibilities who might have them regulary:
http://www.v-zweeden.com
http://www.douglasvalley.co.uk
Old May 3, 2005 | 11:26 PM
UKKid35's Avatar
UKKid35
Tom - http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=4541501963
Alan - Thanks, just what I needed
Jim - Thanks - not really want I wanted to hear. PS have my parents picked up my latest order from you guys yet?
