928 Forum 1978-1995
Sponsored by: 928 Specialists
bilstein / eibachs almost too soft
Old Apr 29, 2005 | 03:49 PM
v-tach's Avatar
v-tach
Default bilstein / eibachs almost too soft
i love the way the new susp handles but i feel that the front is a little too soft ????
any advice? all you racer guys chime in..
thanks
vtach
Old Apr 29, 2005 | 04:41 PM
MarkRobinson's Avatar
MarkRobinson
i have the same, feel the same way. When time permits, I'll cut 1.5 coils off my springs & raise my perches to accommodate. this will stiffen it up about 20% in front or so. Should be "nicer" then.
Mark (5 months now on this setup)
Old Apr 29, 2005 | 04:43 PM
Shane's Avatar
Shane
Sharkaholic
Drive 'em harder they will liven up.
Old Apr 29, 2005 | 05:40 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
I actually felt the same way when I went with new Konis into my stock sport suspension springs. Too soft all around. Cranked the rebound damping all the way. Feels better but still will bottom at times when the original stock shocks did not. The compression damping is not too great on the Konis and is not adjustable.
Old Apr 30, 2005 | 12:40 PM
v-tach's Avatar
v-tach
what about you racer guys - any advice ??
thanks
v-tach
Old Apr 30, 2005 | 12:58 PM
mulik51's Avatar
mulik51
I am not a racer, but by reading some books, I know that when you have a softer suspension, you get oversteer. If you have stiff suspension, you going tto get understeer. If the car, hypothetically, would not have any suspension, and would mount wheels to the frame, you would not be able to turn without understeer on the speeds more then 35 mph. From experience, controlling oversteer is easier and more enjoyable. So, I think that soft suspension(to a degree) is not that bad.
Klim
Old Apr 30, 2005 | 01:14 PM
Drmark's Avatar
Drmark
By too soft, do you mean the front nods on bumping roads? My GTS does this on standard springs and original Boge dampers (only 36 k miles) and I hope to eliminate it by switching to the bilstein / eibach package. Sounds like it might normal for a 928 - am I wrong?
My S4 seems much better.
Cheers
Mark
Old May 1, 2005 | 10:38 AM
Garth S's Avatar
Garth S
Recently installed Koni Gas units in my S4 with stock linear springs ( coded 2 brown stripe front, 2 blue rear) - no nod, wallow, tendency to bottom ... the car communicates every pebble crossed with excellent dampening, and steers more as if on rails: no softness, but not harsh: now it rides much more like the nearly perfect Koni equipped 5-sp
With progressive springs, the idea is relative softness for normal driving, stiffening (progressively) as suspension loading increases. IIRC, most Eibachs sold w. Bilsteins are of this type.
Old May 1, 2005 | 12:30 PM
mark kibort's Avatar
mark kibort
actually, too soft or hard is not the major factor of over vs understeer. one can cause the other.
if you want to stiffen the front, cut one coil out of the front spring. can be done on the car, and doesnt change anything except ride hight .. use the adjustable purches to meet your previous hight. stiffens the front by about 100lbs
mk
