Door Lock LED Question...
#31
Check my post. I had this problem before, I had changed the alarm module, the pulse sender nothing seems to work......but someone from the forum told me to reverse the white connector and force it to connect to the pulse sender....and it works....I don't know why but it works beautifully after since.
Hope this help your situation.
#34
Received 1,317 Likes
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#35
Took the door apart to repair the motor, while the door was apart, the lights start working on both doors. Put everything back together, they stop working again. Which points to loose or incomplete connection?
I want to cry, everything else on this car is perfect.
