Hood pad crumbling
Hood pad crumbling
I installed a new hood pad from 928Intl. on my '87 two years ago and it's already crispy and crumbling. What could I have treated it with when new to make it last longer?
Under the Lift
I always raise the hood on my car when I get home. This vents the huge amount of engine heat that is released and trapped there once coolant and air is no longer circulating and helps to preserve all the rubber on the top of the motor as well as the hood liner. Mine is original and still is good after 140K miles. Same for all the rubber bits. Still, I am surprised too that the new liner had such a short life.
It's the small egg crate foam. I used to mash on it every time I raised the hood and it always seemed soft and pliable. It's like it turned bad suddenly within a month or two - not a gradual thing.
The egg crate liner on the manual I bought last weekend is doing the same thing. If I tough it, it falls like snow all over the engine. Another part to add to the replace list. Thanks for reminding me.
Opening the hood is a good idea....my pad is still in good shape..I guess its original..however several small rubber hood seal pieces dried out, so I replaced them.... Its all good now!
Originally Posted by geekapalooza
I also raise the hood. Only problem with this is every time the wife sees the hood open, she thinks I've "spent more money on that thing".
Under the Lift
I just went out and squeezed the pad in my now 140K mile 89 - not crunchy at all. The aftermarket egg crate replacement must be junk.
