Absolute Power Corrupts Absolutely, President's Day SUPERMODEL Dyno, JR's for BBQ
#61
And an opinion or 5
Originally Posted by Shane
I pretty sure you will find some prices for x-pipe in this thread-->The X Chronicles
#63
Andy:
On the 85 and I believe 86 model year cars there is the little green wire on the ECM's that you can plug together in order to run low octane fuel. I was wondering if that idea had crossed your mind in order to run more boost. I believe that the plug will account for about a 3 degree timing retard.
Regards,
Ken
Regards,
Ken
#64
it does exactly that. I have toyed around with that connector but I leave it unplugged because it just doesn't seem necessary to me. I also have an SMT6 to dynamically adjust timing instead of a solid 3-degree retard... but that's besides the point.
#65
So Mike:
Is the STM6 beyond the electrically challenged of us?
I am in the process of an exhaust upgrade and was toying with the idea of an STM6 in preparation for a supercharger next year.
Regards,
Ken
Regards,
Ken
#66
Ken,
I haven't tried that yet. I was also going to mention for you to cintact Mike about the SM install. Louis Ott sells them.
Here is the complete parts list for the Non intercooled Jag/Eaton systems.
Jag/Eaton M112 Stage1
Item quantity
Jag/Eaton M112 SC w/ pulley 1
M8x50mm Cap Screw (attaching SC) 3
M8 Flat Washer (under front SC bolt) 1
M6x50mm Cap Screw (attaching SC) 4
Manifold 1
Gasket, Manifold (2 on manifold, 2 spare) 4
Barbed Hose Fitting (in manifold) 1
Compression Tube Fitting (in Manifold) 1
1/8" Nylon Boost Gauge Tubing 6ft
Fuel Rail Mount Posts 4
M6 Nuts (top nut on FRM posts) 4
M8x60mm Cap Screws 10
M8 Washers 10
M8x10mm Allen Bolt 2
M6x10mm Allen Bolt 4
Crank Pulley 1
M18x60mm Crank Bolt 1
Power Steering Pulley 1
M6x15mm allen bolts 3
Smog Pump Pulley 1
M6x15 mm allen bolts 3
Inlet, Center 1
Gasket, Inlet Center (1atttached 1spare) 2
M8x20mm Allen Bolts 4
Inlet Passengers Side 1
Inlet, Throttle Body Flange 1
M6x25mm Cap Screws 4
M6 Nuts 4
1.5" Rubber Inlet Joints 3
3.75" Hose Clamps 5
4" Hose Clamps 3
Filter to MAF Tubing 3ft
Air Filter 1
Air Filter Support Ring 1
Bypass Valve 1
M6x15mm allen bolts 4
Bypass Tubing 1
M6x15mm Allen Bolts (in manifold) 2
1.5" hose clamp 1
Silicon Vacuum Harness 1
Cam Cover Oil Breather 1
Crank Case Oil Breather/Oil Fill 1
Oil Fill Cap 1
1" hose clamps 6
Oil Breather/Fill Plate 1
M6x15mm Allen Bolts 2
5/8" Oil Breather Hose 10ft
Fuel Injector Seals (8 spares) 16
Belt, Supercharger 1
Belt, Power Steering 1
Belt, Smog Pump 1
Belt Tensoiner 1
M8x60mm bolt 1
M16x60mm bolt 1
M16 T Nut 1
16mm Hardened Steel Washers 9
Idler Pulley 1
M8x45mm Cap Screws 3
M8x Standoffs 3
Snout Support 1
M8x25mm bolts 2
M8 Nuts 2
Fuel Pressure Gauge 1
FP Gauge Rail Fitting 1
A/F Ratio Meter 1
A/FRM Wiring and Connectors Pack 1
Boost Gauge 1
Boost Gauge 1/8" Compression Fitting 1
Ash Tray Mount Gauge Plate 1
Butt to Butt Gold Plated Connectors 7 (1 spare)
18 Gauge Wire 9ft
1/2" ID Brake Booster Hose 1
7/8" Hose Clamps 2
Zip Ties 12
18 Gauge Wire 9ft
Repalcement Cigarette Lighter Plug 1
'85-'86 Cars Only
Electric Fan 1
Fan Wiring and Relay 1
Fan Mount Hardware 1
Throttle Linkage Mount Bracket 1
Front Throttle Cable Stop (on manifold) 1
Rear Throttle Cable Stop (on bypass valve) 1
Throttle Cable 1
'87+ Cars only
Throttle Body 1
M4x25mm Cap Screws 4
M4 nuts 4
Throtle Linkage Mount 2
Stage 2 '85-'86
Quick Change Pulley Adapter 1
M6x15mm Alen Bolt 2
M8x25mm Allen Bolt 1
M8 Washer 1
SC Pulley 1
Stage 2 '87+
M6x15mm Alen Bolt 2
M8 Washer 1
SC Pulley 1
'85-'86 Fuel Pressure Regulator 1
30# Injectors 8
Andy K
Item quantity
Manifold 1
M8 Washers 10
Crank Pulley 1
Smog Pump Pulley 1
Inlet, Center 1
M6 Nuts 4
3.75" Hose Clamps 5
4" Hose Clamps 3
Air Filter 1
Bypass Valve 1
Bypass Tubing 1
1.5" hose clamp 1
Oil Fill Cap 1
1" hose clamps 6
Belt, Smog Pump 1
Belt Tensoiner 1
M8x60mm bolt 1
M16x60mm bolt 1
M16 T Nut 1
Idler Pulley 1
M8x Standoffs 3
Snout Support 1
M8x25mm bolts 2
M8 Nuts 2
A/F Ratio Meter 1
Boost Gauge 1
18 Gauge Wire 9ft
7/8" Hose Clamps 2
Zip Ties 12
18 Gauge Wire 9ft
'85-'86 Cars Only
Electric Fan 1
Throttle Cable 1
'87+ Cars only
Throttle Body 1
M4 nuts 4
Stage 2 '85-'86
M6x15mm Alen Bolt 2
M8 Washer 1
SC Pulley 1
Stage 2 '87+
M6x15mm Alen Bolt 2
M8 Washer 1
SC Pulley 1
30# Injectors 8
Andy K
#68
So :
Has anyone already installed one of these in an 85 model year?
Does this system allow you to just modify the existing data...I don't want to reinvent the wheel, I'd just like to smooth out the fuel and be able to adjust the igition as needed.
What are the lap top requirements, I'll have to purchase a laptop as well.
Regards,
Ken
Regards,
Ken
#69
i have a crappy k6-3 450Mhz laptop that can barely run win2k. Anything with a serial port that runs win98 or better should work and be decent. Shouldn't cost you more than $250 for such a laptop.
Think of it as a chip that you can tune on your own. You can tune the ignition to 12 degrees in either direction (that's what i've been successful with). As far as smoothing out AFR, you're basically increasing or decreasing the incoming MAF signal to the ECU by small voltages to have the ECU add/subtract fuel to the motor. Your limit here is the lookup map in the ECU. Once you exceed the MAF voltage, you won't be able to add more fuel. What i'm doing is adding a little more fuel via pressure than I need, then subtracting some via the SMT6.
#70
Andy do you sing that list to the tune of the Twelve Days of Christmas? ..And a partridge in a pear tree. But where is the beer,bandaids and BBQ ?
