GM "KLEENS" is nowhere to be found
A very helpful rennlister suggested some "KLEENS" from a GM dealer to clean up the S4 pistons I have. They have carbon in the ring groove and before I send them out to be coated I wanted to really clean them out in there. So instead of ruining the grooves... You know.
Called FIVE GM dealers, and this stuff is San Diego Vaporware - nobody even has heard of it.
Anybody have any idea?
GM# 992872 is the liquid in 500ml cans, # 993026 is the aerosol - reading the label, it is full of carcinogenic goodies that are legal here - maybe not in the US. Smells good, tastes not bad - and like Buckley's cough medicine. it works!
Hmmm. Wooden toothpics. Very good idea.
GARTH - Thanks for the part numbers.
Under the Lift
I used a 1 gallon can of parts solvent from Autozone to descarbonize a bunch of terribly caked up motorcycle pistons. I think Berrymans. Left them in there for 2 weeks. The stuff fell off. Plus Autozone & Kragans sells a ring groove cleaner tool that isn't very expensive and works well.
Hi.
DONT use the ring groove cleaners. They can cause real problems. B.C. try Easy off! don't let it sit on there for long, but it really does a number on carbon and is water soluble and rinses off with plenty of water.
Good luck!
Good luck!
Originally Posted by fst951
Hi.
Good luck!
Good luck!
On very short term contact - and lots of rinse water as fst951 says, they can do the job; however, if the rings are still (stuck) in the grooves or there is a temptation to 'let 'er soak' for a while - Don't!
Aggressive alkaline products can pit aluminium as you watch ...
The rings are out. I'm just to lazy to try and do i t with simple green and now the new idea "toothpics"...
I also have the GTS pistons to clean.
