928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine removal question
Old Jan 9, 2005 | 04:21 PM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
Default Engine removal question
I spent some time disconnecting the last few items and suspending the exhaust. The engine is loose and comes up on the hoist about 5 or 6 inches and then begins lifting the car up with it.
It looks like the bellhousing, which I left on, but disconnected from the torque tube because the bellhousing-to-block bolts are stuck, is getting caught on the firewall as the engine moves up. I don't see that anyhing else is getting in the way.
So...yet another question. For those of you that have pulled your engines (Sterling et al.) with the bellhousing in place, did you run into the firewall and how did you get the engine out?
I'm so close!!
P.S. My rebuilt heads are done and scheduled to ship any day now.
Old Jan 9, 2005 | 04:39 PM
sublimate's Avatar
sublimate
Gluteus Maximus
Did you tilt the engine so the bell housing is down and the front of the engine up? Whenever I've pulled an engine (not on a 928 yet) I've usually had to tilt it by at least 45 degrees. A tilt-bar really helps.
File Type: jpg
Garth S's Avatar
Garth S
Often, the front of the engine is lifted a couple of inches more than the back ( tilted) and advanced forward the same amount (roll the chassis back or engine stand forward). That should allow firewall clearance.
Old Jan 9, 2005 | 05:04 PM
Big Dave's Avatar
Big Dave
I've got the bar that tilts one side vs. the other. If I set it so it favors the passenger/front lift point, should that tilt the engine so that the front end is higher? I think I've been doing the reverse...adjusting the bar so that the back end is lifted higher. Duh. I'll have to wait until this evening to try again. I'm now playing Mr. Mom while my bride is out shopping.
Old Jan 9, 2005 | 05:14 PM
sublimate's Avatar
sublimate
Gluteus Maximus
No need to wait - kids can be a great help when removing an engine. I like to use them as padding to keep the engine from banging into the fenders.
Old Jan 9, 2005 | 05:18 PM
SharkSkin's Avatar
SharkSkin
Dave, now that you can move the engine around a bit, can you get to the last bellhousing bolts and remove them? Just a thought...
Old Jan 9, 2005 | 06:03 PM
Big Dave's Avatar
Big Dave
Theyll certainly be coming off once I can get straight at them. I need them off to mount the engine to my shiny new stand.
sublimate....LOL!
Old Jan 9, 2005 | 06:05 PM
Z's Avatar
Z
They've got little hands that can get at some of those hard to reach nuts and bolts too. Just grab them by the ankles, lower them down head first, and they can probably get at those pesky bellhousing bolts with no problem!
Good luck Dave. Sounds like you're really close now.
Old Jan 9, 2005 | 07:22 PM
hupp's Avatar
hupp
Dave,
I don't know if this usually applies to your year model, but make sure you have removed all of the wire harness brackets. One wire harness bracket was hidden just on top of the cross member. I nearly lifted my shark by the harness because of this.
I removed my engine with bell housing attached as well, but my AC condensor was not installed so I had a bit more forward room. You may have to resort to removing the fan from the front of the engine to give yourself a bit more room.
Old Jan 9, 2005 | 07:25 PM
BC's Avatar
BC
The AC lines caught when I pulled the 78's engine/ And the rear banged up the AC lines. Those two places I would suggest watching.
Old Jan 9, 2005 | 07:44 PM
Big Dave's Avatar
Big Dave
The fan is already off, but I need to check out the wiring stuff. I think I have everything disconnected, but I need to look again. Hopefully I'll have the engine out tonight if I get some more time to go out to the garage.
Thanks everyone.
