928 Forum 1978-1995
Sponsored by: 928 Specialists
Rear AC Removal
Old Jan 6, 2005 | 01:49 PM
Jim_H's Avatar
Jim_H
Default Rear AC Removal
Removing the rear AC from my 91 GT. Any secrets? I didn't find it in the manuals.
THANKS!
Old Jan 6, 2005 | 01:57 PM
BC's Avatar
BC
I did this on my 89 Jim. Rear unit has hard lines comming from front hard lines under the car, UP through the floor under the pass seat, into a coupler, and up the tunnel to the exhanger. They constantly leak. You'll need to either cap off the lines there at the coupler, or even better where there are some threaded connections under the car (passenger side).
There is also a electric valve thats heavy and under the seat as well. I have no idea why they even did the system this way. Some wires go back there too, to control the fan, etc. There is a drainage line for the exchanger that you can cap off under the unit.
I took my hard lines out (you probably can't with the engine IN) and am having the braches welded shut.
When you remove the union in the floor there will be a 2 inch gaping hole there. I still haven't figured out how to close it up.
Old Jan 6, 2005 | 02:20 PM
Jim_H's Avatar
Jim_H
Thanks Brendan, that's the info I was looking for.
Old Jan 6, 2005 | 02:28 PM
aaron3's Avatar
aaron3
Jim and or Brendan, what are you putting in the place of the rear a/c? Can you easily retrofit it with the rear glovebox type? Any idea of the cost?
Old Jan 6, 2005 | 02:35 PM
BC's Avatar
BC
I have a rear leather "hump" from an old 81 that I could use, if its recovered.
I was also just thinking of having some paddin put down and some nice smelly leather. Whatever is lightest.
Old Jan 6, 2005 | 02:45 PM
Jim_H's Avatar
Jim_H
Aaron,
I have a rear glovebox that I will be sizing tonight so I will post follow up tomorrow. Like Brendan said you can just cover. My back up plan is possibly my CD changer going there.
Old Jan 6, 2005 | 02:47 PM
aaron3's Avatar
aaron3
Brendan,
I'd be interested in knowing what the 'space where the a/c was' looks like. Might bring some ideas as to what could go there. If you have pics I'd like to see them. If not, no problem.
Old Jan 6, 2005 | 03:04 PM
BC's Avatar
BC
Uh. let me check. They aren't pretty as I recall.
Old Jan 6, 2005 | 03:06 PM
Tom. M's Avatar
Tom. M
Deleted
Hey Jim,
There is a local up here who has done the same thing.....you should contact him...uh...ohh..ummmm..never mind.... :-) ha ha...
later,
Tom
midlman@rennlist.net
89GT..no rear air :-)
Old Jan 6, 2005 | 03:15 PM
Jim_H's Avatar
Jim_H
Can't imagine who you mean?
Originally Posted by Tom. M
Hey Jim,
later,
Tom
Old Jan 6, 2005 | 03:27 PM
BC's Avatar
BC
These are kind of far away. This one is my car pre-cleanup:
And here we have big bird:
Old Jan 6, 2005 | 03:33 PM
Earl Gillstrom's Avatar
Earl Gillstrom
Rest In Peace
Jim,
If you remove your rear AC don't throw it away. It has value, especially the evaporator. They leak and are difficult to fix.
Old Jan 6, 2005 | 06:17 PM
Jim_H's Avatar
Jim_H
Thanks Earl, nothing Porsche related enters my garbage can
Originally Posted by Earl Gillstrom
Jim,
Old Jan 7, 2005 | 12:37 AM
Jim_H's Avatar
Jim_H
Mark,
Here are some pics I took tonight. Straightforward job. I had to take the back mounting hex bolts out from the front seat so I could lift it a bit to remove the lines. They used some ferocious glue on the carpet/vinyl that runs under the back seat.
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 7, 2005 | 12:39 AM
Jim_H's Avatar
Jim_H
Man those 1st three pics suck. Must not have had the flash on.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
