Rear AC Removal
Looks damn familar.
So the hard part begins? Removing the lines from the underside towards the front, and I do have my motor in. And no it ain't coming out.
BTW nice job on the cage in your Shark.
Originally Posted by BrendanC
Looks damn familar.
Those seat lines have been replaced.
Yellow car is not mine. Falkenberg's.
Cottage Industry Sponsor
Originally Posted by Earl Gillstrom
If you remove your rear AC don't throw it away. It has value, especially the evaporator. They leak and are difficult to fix.
Jim,
Thanks for the pics. Looks like you the job pretty quick. How much does that assembly weigh? Looks huge. I'd say you could put almost anything in the middle there. Probably could cover it fairly easily and have it look nice.
Jim, I removed mine last spring, and decided to use the mount area for my stereo amps. Made a platform out of speaker board, covered it in vinyl, and bolted it to the 4 mount holes for the rear a/c. Then I mounted my amps to that, so there is no hardware showing.
