No Trust Possible Among Rennlist Members?
928 Collector
How the hell did you squeeze ONE-INCH spacers in there??? Is this for your GTS? In that case, take a look at GTS wheel offsets. One inch spacers come stock on your car, and I wouldn't hold the seller responsible for that ....
928 Collector
OK, Stefan / Ron .... just so you guys both know, I think you're both good guys with a sad misunderstanding. That's all. I was just asking enough info to make my own mind up ..... Cheers Guys, hope you guys work it out.
Heinrich
Heinrich
Would a reasonable person put those wheels on a 928 and be happy? Would a reasonable person notice the variation in the tires? What are the wheels worth w/o tires? If they are a better fit on a 911 maybe you should sell them and move on. Used tires are not worth a lot, I do not see having the seller on the hook for full price of new tires.
-Joel.
-Joel.
Just purchased a new set of twists from 928 Int and while i haven't mounted them yet, they look perfect. My question...and maybe i should be calling 928 INT direct instead of using this public forum...is on the off sets....Stefen mentions the front/rear offsets were wrong...it never crossed my mind to stipulate offsets, as they are going on a 928 and i assume they are all the same...Mark, if you could reply id appreciate...thanks
The Parts Whisperer
The most commonly sold aftermarket wheels that fit a 928 are as follows
7.5x17 front 49mm offset
9x17 rear 52mm offset
On the GTS Porsche used the following:
7.5x17 front 65mm offset
9x17 rear 55mm offset
By using the aftermarket replicas the fronts will stick out 8mm more than stock and the rears will be in by 1.5mm. With the stock GTS tires sizes this has yet to be a problem. If you are looking for the exact offsets as used by Porsche you will usually need to get factory wheels.
Gluteus Maximus
Originally Posted by Sharker Image
it is an S4
the spacers are needed to get back to the same track ratio as original
the wheels and the spacers do not fit the car
Now known as aka "the Seller", I would not have taken my time then - or now were I not of the impression that I was dealing with a solid, credible Rennlist member.
It is clear that the Seller was inexperienced in tires, wheels, ET, spacers, etc: That is hardly a crime, but a learning stage ( in related posts, the ETs quoted were confused and subsequently corrected - clearly in error and not by intent). The satisfying result was that in the end the wheels fit!
Knowing the tire game reasonably well, it is pleasing when the 1 in 100 ( or 1 in a thousand) individual is aware of the fundamentals of differing internal tire construction that merit N0, N1, N2, M2 etc. sidewall designations ( specific to Porsche, Nissan, Mercedes, etc.) - at that time, I had no reason to believe the Seller to be that rare individual . IIRC, the tires were in matched pairs by size designation and model - the sole criteria for many unaware of the 'N1" difference.
With those points in mind, it is difficult to accept that any "Buyer" dissatifaction is attributable to willful misrepresentation by the "Seller" - dissatisfaciation there is, but if it is presented in the public fashion that it has been, then opinion is invited: My opinion is that there is no basis to challenge the Sellers character.
The question of track ratio and adherence to OEM design criteria would, from first principles, preclude purchase of any 18" wheels - obviously as they were never a factory offering. 'Customization' would be the area with 18s, and these same wheels have been fitted to at least two 928's - it is a shame they will not fit a third, for the ETs are within the realm of many successful fittings. Agreed that more front negative offset than 52mm is desirable - but there are a lot of happy owners with ET50 steering the fronts.
I suspect these wheels will again find a happy 928 home - in another place ... let it pass, but why chew up someone's character over a disagreement: When this thread started, it seemed by the response that a lynch party could have been formed - it's like tossing a bucket of crap into the wind: there are no winners, everyone gets spattered: I feel spattered in brown just from reading this ....
In Your Face, Ace
I purchased my wheels and tires from a Rennlister and he was a total standup guy. He originally had them listed on e-bay, and then posted it here. We closed the transaction without even going through ebay.
I don't think many here would ever make a bad deal on purpose or screw someone over. My reputation is not for sale, and any regular user is likely to value their own reputation and will probably always try to make good on a deal done here. As for ebay, I have been happy with all of my purchases but one. And that's when none other than the infamous Robert Hack got me for $80.00.. Had I done a search here before dealing with him, it would have saved me the hassle. So the moral is, Rennlist and it's members are your friend!
Thanks for the reply Mark.....i guess the bottom line is if i can mount the tires and bolt the new rims on my car without worrying about offsets/spacers etc, i'm happy....obviously there are a lot of people running the Hartman aftermarket twists without problems...
so it wasn't my last posting!
it is a fact that the OEM BMW tire and the OEM Porsche tire have different tread patters - this will be confirmed by any knowledgable tire store and by Bridgestone themselves.
>>>>>>>>>>>>>>You mean that BMW and Porsche marketeers have jumped in bed with different tire manufacturers?? yes, then you are right. but, as far as which tire will work on which car, its really a factor of taste. all will work equally on both cars. From a racer perspective, all street tires are pretty bad anyway. its just a matter of which one is "least bad".
yes, one might fit those wheels on a 928S4, not caring about the track ratio, etc.
>>>>>>>>>>>track ratio????? huh?????the car will work with all sorts of wheel combinations. as long as they fit under the fenders and are not rubbing on the inside or out, they are fine! obviously, looks best when they are farthest out.
and yes once more, the car will go to top speed with those wheels/tires in a straight line (one better buys a muscle car to do the 1/4 mile).
but no, once you drive it hard in a series of corners, you will feel the difference between the two tires.
>>>>>>>>>>>>>>what kind of difference?? if there are differences, they are going to be very subtle
i have a FIA issued racing license and co-own a well know tuning company at the other side of the atlantic. i am sorry to have made the mistake to believe that all Porsche owners and stores are technically up to date overhere.
>>>>>>>>>>> lets hope you are using that licence to help understand the reality of tire performance!
and finally: nobody offered to buy the wheels and tires (how does it go here: put your actions .......)
<<<<<<<<<<<<<<<<sorry, i just have to chime in when it comes to folks getting all worked up over street tires and manufacturers "recommended" oil, tires, gas, etc!!
also, sorry to chime in on this thread, in that there really is a complaint of misrepresentation of the wheel offsets (yes, a big deal) and the tires. If i was told that the tires were all the same and they came out to be a "little" different, i would be upset too. not that they wouldnt work just fine (reason for my post) but for the reasons of truth in advertising.
again, sorry for the subtle highjacking of the thread.
