Lm-1/3 Wide band O2 logging
#46
Is the stock NB O2 sensor something I could buy at an auto parts store? I might as well go and replace it today while I wait for the delivery of the Innovate stuff.
#47
Originally Posted by aggravation
Crap! I just ordered the LC-1 as part of the XD-16 stand alone kit, I was hoping to use it and the WB sensor that comes with it and replace my stock NB O2 sensor since I suspect it may be malfunctioning.
So should I install a second bung and only use the LC-1 wide band set up for the AF gauge and replace the suspect sensor with another NB sensor to feed the computer?
There isn't a whole lot of room in the H pipe to put another bung in but I could probably do it, the hard part would be putting it in next to the existing one to keep the body of the sensor upstream of the heat flowing off the pipe...I'm guessing that might make a difference.
By the way, excellent thread, I'm learning lots from you guys!
I have done exactly this....... LC-1 / XD-1 permanently installed. LMA-3 and TC-4 daisy chained in along with laptop for engine logging & tuning. Plus the LC-1 feeds A/F information to my SharkTuner.
I have a second bung installed in my X-pipe, in the mirror image position to the first one. There is more than sufficient room under there on my X-pipe/car.
Originally Posted by Andrew Olson
That's how I have mine set up. But my O2 bungs are welded on the down pipes (one on eeach side) from the header to the X-pipe (H-pipe in your case). BTW, I still have my Aux box sitting in it's box. I just can't seem to find time to get out into the garage and fiddle with it. ![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
#48
Originally Posted by BrianG
IYou can buy that 3 wire sensor almost anywhere but you will likely have to splice in the 928's connector plug. No big deal. Get a sensor with the "long" lead. (they come with "long" or "short") Take the old one with you....
So I'll be off the NAPA, AutoZone etc. with hopes someone has one in stock this morning!
#49
#51
Originally Posted by John Speake
Hi Greg,
The issue appears to be with the LC-1, not the LM-1. Which type are you using ?
The TechEdge units appear to be relaible.
John
John
I have heard lotsa complaints about other WBO2 units, but, as always, your experience may vary. I'm also convinced 70% of all complaints are from those who don't know how to do it, and won't RTFM...
I'm running the LM1 (I actually have a couple). When I initially got into the Innovate WB and datalogging they offered no products but the LM1 and the rpm convertor. The aux box was over a year away (actually longer IIRC).
I had to scratch build my own 'aux box', which was really not terrribly hard - it is a bit bigger than Klaus' box obviously. (I put in a couple of MAP sensors, Pulsewidth, and some 0-12/0-5v scaling circuits for flexibility).
While I was at it, I also built a break-out box for L/LH, so I can tap any I/O right in the passenger seat. Between the Innovate, a very inexpensive 4 ch laptop input unit and more expensive 16 ch laptop input unit, I can log just about anything to do with the engine functionality. By the individual cylinder.
The only thing I can not currently do is ion-feedback loops of PPP - someday when I have some time I will hack the unit that's lying around and figure out how to tie it into my stuff. Or just scratch one, there's a few white papers floating around on it.
Cheers,
Greg
#52
Hi Greg,
I am just repeating other people's experience with the LC-1. But Innovate may have fixed the issue with a software update by now...... I hope so because they are good products other than this one reported problem.
#53
John, as I said, I have no first hand experience with that particular product, so, honest, I'll take your word for it.
I just meant that it seemed odd, but hey, odd hardly equates with impossible.
Greg
Greg
#54
Originally Posted by Bill Ball
Brian, et al.:
What length lead did you order with the LC-1? I went with 1 meter. Hope that is enough.
You will pass the 2 serial leads and the main wiring harness lead through some grommet (like the OEM 02 sensor one) into the passenger compartment and do the hard-wiring there at the fuse panel anyway. One m of length is pleanty.
#56
Supercharged
#57
Supercharged
Binging this back up to the top.
I finally got time to monkey around with my Aux Box this past weekend. I've got it tracking boost and RPM right now, although I need to monkey around with the boost measurement. I just re-read Tony's dealings with this and I see that I need to change the function number for the boost.
Anyway, I would have also recorded AFR except for 2 things. #1, I didn't have the male-male serial plug and #2 when I did my clutch and re-attached the lower bell housing cover, I inadvertently pinched the WBO2 cable in the cover and squashed the wiring. I thought I had fixed it, did a free-air calibration, but it won't work. So, I've got a new on the way.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Question: Where is the best place to thermocouple? I'm thinking I'd probably want to record IC inlet and outlet temperature differential, but I'm unclear as to where I should attach the thermocouple wire to record these values. Any tips?
Also, has anyone else here mounted one of these Aux Boxes in a 90+? I don't have the parcel tray, so finding an appropriate place to mount it to take advantage of the accelerometer is a challenge. I was going to velcro it to the underside of the glove box, but it's not level with the car. Any ideas?
#58
<snip>
<snip>
One possible location for the Auxbox would be on the floor under the carpet. I think over on the side next to where teh LH/EZ-K is located would be out of the way of passenger feet. Cover the Auxbox with thin plywood or sheet metal for added protection.
#59
I'm using the LM-3 to log RPM, vacuum/boost, injector duty cycle, fuel pressure and one temp. I have heard that the accelerometer is somewhat flakey.
I also picked up a TC-4 for more temp data. I think I'll pick up the intercooled air temp with a probe into one of the 2 vacuum ports already in the manifold. I'd also like to have intake air temp, compressor outlet temp, and underhood temp. If I do end up with one channel left on the LMA-3 I might grab coolant temp so that I have accurate data there, too.
Tony might chime in here with ideas for locating the probes, as he was monitoring 4 temps when I saw his car in Las Vegas last winter.
#60
Supercharged
Thanks Louis and Brian. ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
I have a G-Tech Pro SS which I can use for Acceleration, I just thought it would be nice to have all the data on one page, but if it's not reliable, I'll just shove it under the cover with the LH and leave it be.
Brian, how hard is it to record the injector duty cycle? Is that something you can pull off the LH/EZK harness or do you have to fish a wire up an injector?
A question for anyone with an Andy Keel or DR's setup (sorry Brian, I don't recall what you have). where's the best place to recod pre/post IC air temperatures? Per Louis suggestion, you don't want to clamp it to a tube or something like that as that's not recording the air temp but the affect of air temp on an object. Just looking for additional ideas.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
