928 Forum 1978-1995
Sponsored by: 928 Specialists
Things that happened to the S4 this morning
Old 12-22-2004, 04:55 AM
  #46
928Quest
928Quest's Avatar
Kibort - "Actually, the 928 manual is 1:1 when in 5th gear. (ie 2.2:1 is the total ratio in 5th gear. with a 25" diameter tire, thats 78.53" circumference.
SO, that is 478mph at 6400rpm wth no reduction. Now, just plug in your ratios and have fun.
4th on an S4 is 3.2:1 (for example) that works out to 150mph with a 2.2:1."
I am not sure where all of the above comes from. I think the 89 auto configuration ia similar to my 91 setup. My 91 has a 2.53 rear end, 4th is 1:1 and 3rd is 1.44:1. So final drive ratio is fourth is 2.53 and in third is 3.64. I think the 89 in question would be similar.
My 91 manual clearly states a top speed of 165 for the auto. I have had mine to 150 and had plenty left to go.
Where your number of 3.2:1 for final ratio comes from I don't know. Also using your tire size and speed calculations puts a 2.53 rear end S4 top speed at 188 in fourth (assuming no drag) and 133 in 3rd.
Old 12-22-2004, 11:51 AM
  #47
mark kibort
mark kibort's Avatar
I was clearly speaking of MANUAL 5 speed transmission with the 2.2:1 final drive, as well as my reference to the 3.2:1 total ratio for 4th gear , also in the manual 5 speed.
mk
Quick Reply: Things that happened to the S4 this morning
