can someone please explain this to me? Does my radiator cool 3 fluids?
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Again, still in the pursuit of finding the hose thats leaking I've discovered some interesting things in the cooling system of my 928. First of all, the ATF leak is coming from the front passenger side of the car and I have been told its the line that's right below the upper radiator hose.
What someone else told me in a previous thread is that if I have a line thats on the driver's side upper part of the radiator, than its a radiator used to cool oil...well now here's the big confusion part. Does my radiator cool 3 types of fluids!? ATF, coolant and oil??? pictures are below....
It is my understanding that the radiator for the Automatic Tranny sharks do cool the Rad Fluid - the tranny fluid and the oil. There is also an extra tranny cooler (Pre MY ?) - Someone please correct me if Im wrong.
Thanks!
Thanks!
Fuse 24 Assassin
Fuse 24 Assassin
Drewster what I don't get is why 928 Intl specifies my radiator as a 2-cooler radiator if auto cars cool all 3 fluids
BTW I added a PET diagram of the hose leaking. I hope that's the right one if thats leading to the leak.
Here's the link for my model, I think.
http://www.mailordercentral.com/928i...em=14&mitem=80
'2 cooler' means two EXTRA coolers, one in each side tank - ie tranny fluid and engine oil. Its not a count of the number of fluids being handled. Its assumed you know its mostly cooling engine coolant. Do you want to call a normal radiator (with No extra coolers) a zero cooler radiator when its doing 1 fluid?
jp 83 Euro S AT 48k
jp 83 Euro S AT 48k
Fuse 24 Assassin
Fuse 24 Assassin
so the 2-cooling means 3-cooling actually, including the radiator fluid. I feel really retarded now At least I can understand the cooling system on this car a little more. Next year my father turns full ownership over to me and my half becomes whole. The least I can do is study this car and do a better job at maintaining it since I will learn more about it.
Thank you very much you guys. For everything as usual.
Stig - rather than ordering new cooler lines - have your old ones rebuilt. There are shops out there that all they do is rebuild liquid lines. They take your old ends and install new hoses. I had this done on my 87924S when my a/c line was leaking. 300.00 vrs 35.00.
Also - thanks to everyone for the "inside" info on the cooling properties.
Thanks!
Thanks!
Generally engine coolant warms up quicker than engine oil or tranny oil, and stays at a more stable temp than the oils would otherwise, so intercooling them helps to stabilize the oil temps. Note that the engine oil lines have a thermostat to stop the oil going to the radiator cooler when the oil is cold at startup.
hth
jp 83 Euro S AT 48k
hth
jp 83 Euro S AT 48k
Fuse 24 Assassin
Fuse 24 Assassin
Thanks guys for all your help and the suggestion. Tomorrow I'll attempt to locate the leak with my buddy with the help of his rack at the shop he has.
Andy,
The PET diagram is incorrect, in that it shows the short ATF hose connected to the transmission cooler (in front of the radiator) on the bottom connection. It's possible to install it there, but the service life will be reduced considerably due to the manufactured length which would stress the hose fitting near the radiator side.
