Side Moulding Holes Welded
I posted this to our local group but thought some of you might find this interesting, so I removed the side mouldings in prep for some Winter projects and have heard all the horror stories about welding on the doors and fenders. Well I found a local guy who was recommended by a couple of hot rod shops, i'd never have gone to his shop without those leads as a shack would be overstating its appearance.
However the guy can weld, he used some special putty/clay to draw the heat from the weld area so as not to warp the panels.
Chris
![](http://forums.rennlist.com/upload/body4.jpg)
Chris
Administrator - "Tyson"
So, if you ever sell the car, I can't wait for the new owner to show up here with a post "how hard is it to add side mouldings?"
Shane: Yep but going for something a little less matt, somone at Octberfest had their Rubinrot redone and it looked really nice but wonder whether it was Granatrod, will do some color sampling for sure.
Hacker: Yeah well you can never tell what a future owner will do, sure would be a lot easier to put back on thats for sure.
Chris
Chris
Cottage Industry Sponsor
Thanks for the info, Chris! Some day....
Just remember: Even if you do a subtle color change, you'll have a lot of disassembly to do. Only you can decide, if it's worth it for you.
Chris - Why repaint? Just cover it up with a big white Starsky and Hutch stripe down the side
I'm with you, I plan on ditching the molding when it's repainted. The molding probably saves a lot on door-dings, but it just busts up the look--especially the rear qtr. How many hours labor did he charge? Just trying to gauge a good estimate when I hear one.
Thanks,
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Thanks,
That stripe would look classy for sure, tell you that glue they use for the mouldings is strong, need a sander to get it off.
He charged me $200, no mention of hours but I thought that was OK.
With/without side mouldings is a personal thing, kinda depends on the color also, but with aero mirrors I decided it looked a lot better without.
Chris
Chris
Chris you're very fortunate to have found this guy. That's an old hot rodders trick. I got turned on to this by some pro hot rodders while restoring vintage trucks. Most modern day sheet metal guys would have opted for the old "putty is my buddy" routine. Jewelers use the same sort of technique to protect precious stones from damage. Be careful when it comes time for paint that those areas receive a little extra light sanding and primer so that weld spots don't mirror through. Post some pics when done.
Off Subject: Hi Nicole! Recognize that car in my avatar? In your honor.
TIG or MIG Chris?
USMarine
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Chris you will have to seal the weld in the interior of the wheel well. If there are any porus areas in the weld (there usually are) you will have troble with the paint bubbling on the outside. I tried several different types of products to seal my welds and each failed after a period of rain and driving in the wet. I ultimately ended up using an interior sealant made by MercBnz and it solved my problem there after.
![](http://patedwards.net/images/restoration/exterior6.jpg)
![](http://patedwards.net/images/restoration/exterior12.jpg)
p@
p@
