928 Forum 1978-1995
Sponsored by: 928 Specialists
Fan question
Old 10-26-2004 | 02:09 AM
Airflite40's Avatar
Airflite40
Official Rennlist
Borat Impersonator
Default Fan question
I was doing some research today on Illinois Emissions Laws, and I was able to find out that there is no visual inspection, and for cars of MY 1968-1980 they only test at idle. This is goods news for me, since I dont have a cat, and I am planning on removing the air pump. I also have removed the A/C compressor and lines. I remember a while back reading that one can delete the belt driven fan and replace the stock electric fan with a newer and better one, and actually improve cooling. Is that possible? If so, which electric fans are known to work? I tried searching the archives, but I couldn't find a clear answer.
Old 10-26-2004 | 04:01 AM
jserio's Avatar
jserio
https://rennlist.com/forums/928-forum/166192-two-high-flow-electric-fans.html
I think you can ask Jack that question. I think he has an early year with viscous removed.
Old 10-26-2004 | 04:33 AM
SharkSkin's Avatar
SharkSkin
I haven't deleted my belt-driven fan, but I replaced the front fan with a 16" Spal fan having 2-3 times the output(depending who you talk to). Pic below, more details here.
Hmmm... for some reason the image isn't showing up in post preview... so here's a link: http://members.rennlist.com/sharkski...edFrontTop.jpg
Old 10-26-2004 | 04:59 AM
Airflite40's Avatar
Airflite40
Official Rennlist
Borat Impersonator
I have looked at your site, Dave. Great Job!!!
Old 10-26-2004 | 05:25 AM
SharkSkin's Avatar
SharkSkin
Thanks Borys....
BTW I have heard that there is a 16" Hayden fan available at Autozone, Pep Boys, etc that is pretty straightforward to install using the stock brackets. I didn't actually try to do the install... I went and looked at a local Pep Boys and the best 16" Hayden fan I could find was rated about 500CFM less than the Spal. IIRC the hayden was ~1700CFM.
HTH
Quick Reply: Fan question
