16V L-Jet supercharger updates? Anyone?
#31
Developer
One more thing - yes, it needs a cold-air intake for the air filter. Agreed. I have it designed.
No problem, there are big deals and little deals and thats a little deal.
#32
Originally Posted by John..
So you're saying a car running 9 lbs with the CS making less than 300 ft-lbs will outrun a car running 9 lbs making over 350 ft-lbs and 20-30 more HP?
For the record, my car can do 0-60 in 5.5 and mid 13 seconds at over 113 MPH. I would assume Carl's is faster down low because of available boost in 1st gear.
You want to try a 50-120 MPH roll on, real world type stuff?
Let's compare the apples to apples here.
None of you have ever seen my Callaway twin turbo
and I will remind you all, again, those performance specs were before I ever touched the car.
Originally Posted by John.. in another thread
I am saying Brendan has a big mouth about boosted 928s for having never done anything remotely like this to his car. I've spent the last 10 years working on mine, and from the level of preperation, design and fabrication I have done does grant me some knowledge on the subject at hand.
Yes, it seems to me I added 70 or so HP to the equation already.
The specs you quote are for Carl's race car, which I believe has the Euro heads and camshafts.
If you think changing manifolds is a big deal, then the TT is not for you. Personally I think that is an easy job.
I have given some thought to selling the piece parts, clearly the hardest items are the manifolds and wastegate integration pipes. These are carefully designed to fit within the 928's stock chassis and sneak by the steering shaft. Space management would be an understatement.
For those who have the patience and desire it is a great setup with performance to match.
I suggest you hold back on your comments, need I remind you how I shot holes clean through Lag-Algebra last year?
I think it is interesting that you're following along the same path of trying to sell turbocharger installations on 928s like Callaway did. You might also learn something he did too. I think I remember you once saying that he sold a total of five of them. That was back when the cars were still worth a considerable amount, and a car that had performance numbers like yours was pretty rare when compared to other new cars of the time. You're not the only one that's started down that path since then either. That guy up in the Pacific Northwest that's been mentioned before only built one twin turbo S4. Apparently the customer never even took delivery when it was finished, and the car was never really driven since being built about 15 years or so ago. Years ago there were a few people talking about the high power turbo 928s that they were building using 944 turbo components. Seen any? I know the guys at FAST started on 928 turbo development, but then went to the centrifugal superchargers instead. Even with there being some reported issues with their centrifugal setups, they've sold more of those than all of the different turbo 928 guys combined.
Maybe it'll be different. Maybe people are finally ready to buy turbo installation kits that cost more than the cars they're supposed to go on, for performance that's less than even many current stock luxury cars and even some SUVs and pickup trucks, and that makes less horsepower than some normally aspirated Hondas with engines a fraction of the size.
#33
Did I hear my name?
#37
Developer
Are you waiting for me?
My appointment at the Dynojet Dyno is at 1:00 tomorrow (Friday 18th)
with the supercharged L-Jet. I will post chart and air/fuel info.
I have had her out on the backroads today and I think I have the air/fuel tuned in pretty well. She stayed nice and on the rich side of things thru 8 psi at 6000 RPM. This observation is just by the air/fuel gauge inside the car. Tomorrow I will have numbers.
#39
Originally Posted by SharkSkin
I think Tony & I were both referring to the same thing... Z's post.
yup, dont sweat it Carl. Then again, your in Wisconsin and you cant sweat this time of year anyway
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#40
Woo-hoo! Carl is coming through with the goods! Way to go Carl!!
Carl, it looks like you are blowing straight through the stock AFM. There have been a number of hypothetical discussions on this topic, some claiming that this won't work. Looks to me like it does. Have you discovered any AFM or fuel mixture problems? And, what if anything are you doing to compensate for boost -- RRFPR, piggyback electronics etc.?? What does tuning the A/F ratio involve?
This looks great!!
Rick
This looks great!!
Rick
#41
What's up with the 'factory' 16V installs, beeayatch?
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Andy K
#42
Inventor
You were too quick, Andy! I deleted the post, cuz I wasn't sure if you wanted to get caught up in this thread... anyway, restored from the cache for context.
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
Originally Posted by PorKen
GoRideSno,
You've been suspiciously quiet on the fate of 'Brown Suga', and the 'Tar Baby'.
post 1400!
![](https://members.rennlist.com/porken/smiley_3gearsauto.gif)
#44
Thanks for your consideration Porken.
I won't get caught up in the fray though.
Seasoned FI fans know the true technological hierarchy of systems with turbos at the top. No need to argue, facts are facts.
That's why this sitcom is funny enough to have made it to the 2nd season.
I think a better comparison than That 70's Show though would be Hogan's Heroes. I guess a mix between the two would be most appropriate, Hogan's heroes but set in Wisconsin. John would be Hogan imprisoned (on the internet atleast) by an army of the mis-guided that wants to take over the world with their master centrifical plan. Of course it's a comedy of errors by all but the hero John.
We'll need a new theme song and a prelude to the show. As the commercials end........
Imagine a loud whistling/whining noise in the background as Z, Lag and the crew are all riding in a Black Vortech SCed 928. They'e wearing funny looking uniforms tall jack boots, long gloves and a symbol on their uniforms that looks like a Vortech impeller. In each's hand is their favorite beverage. They are lipsynching the words to this song.
Hanging out
On Rennlist
That same old thing
We did last week
Not a thing to do
But F with John..
centrifugals are right
all else is wrong
(bridge)
Hanging out
On Rennlist
The same old thing
Like packing cheese
Not a thing to do
but per-se-cute (anything that's not centrifical and/or from WI)
We're all always right
You're all always wrong
HELLO WISCONSIN!
ANdy K
Hanging out
On Rennlist
That same old thing
We did last week
Not a thing to do
But F with John..
all else is wrong
(bridge)
Hanging out
On Rennlist
The same old thing
Like packing cheese
Not a thing to do
HELLO WISCONSIN!
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
ANdy K
#45
Developer
From FJTW -
Yes, many of the same folks who told me you cannot blow into CIS have told me you cannot blow into L-Jetronic too. I have been driving this car for 2 days now, cold starts, warm starts, 6,000 RPM runs, EVERYTHING and I can tell you I have it tuned to where it idles smoothly s at 800 RPM, blips up to high rrr's very very quickly, returns right to smooth idle. Pulls hard from about 3300 to 6000 RPM.
There have been some "discovery" items, and a learning curve with the L-Jet - especially the L-Jet intake shoe (below the throttle body). I was able to stay away from auxiliary injectors, larger injectors, and expensive and complicated EMU systems (piggyback electronics). Like our other kits, we like to be very efficient and make as few changes as we can and still get it right. It keeps costs down, and simplifies installation and maintenance.
I do not want to say too much yet - I want confirmation of my air/fuel ratios at the dyno tomorrow. Mike Schmidt is going to try to meet me there at 1 if he can.
I've been looking all over for my G-Tech Pro in the hopes of posting a acceleration chart, or a 1/4 mile run. Cannot find it. Found my old one - G-tech Original model. It might give me at least a 1/4 mile idea of what's going on.
