928 Forum 1978-1995
Sponsored by: 928 Specialists
Air pump question....
Old 09-26-2004 | 12:38 PM
JKelly's Avatar
JKelly
Default Air pump question....
After putting on my new x-pipe (see here for details) I now have to deal with the air pump. Has anyone put a metal valve on the end of the pipe to control the backpressure enough to make the sound stop?? or would this be bad. I guess it might smoke a little bit if I did that (?). I don't want to "delete" the air pump yet. If I slighty block the pipe with my finger while it's running, the noise stops, but there is still air flow coming out of it. Or, would it just be better to get a 21" belt and "jumper" the fan?? Thanks
Old 09-26-2004 | 12:48 PM
GlenL's Avatar
GlenL
I took apart my air pump and removed the vanes. That fixed the sound. I still use it as a belt tensioner.
Old 09-26-2004 | 04:01 PM
SharkSkin's Avatar
SharkSkin
You could get the euro belt tensioner... it's basically an idler pulley that mounts where you have your smog pump, and it allows you to use the same belt and tension it essentially the same way you do now.
Old 09-26-2004 | 08:14 PM
Greg86andahalf's Avatar
Greg86andahalf
Or remove the air pump and use a 20 or 21 inch belt direct from the crank pully to the fan. That's what I did and it works like a charm
Old 09-26-2004 | 09:54 PM
Ed MD's Avatar
Ed MD
How do you tighten the belt then?
Ed M
85 928S, 88 928S4
Old 09-27-2004 | 10:53 AM
Greg86andahalf
loosen the fan carrier, slip the belt over the fan pully, tighten the fan carrier and the belt snugs up.
Old 09-27-2004 | 11:15 AM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Air pump removal:
https://rennlist.com/forums/928-forum/132878-short-fan-belt.html
Old 09-27-2004 | 11:37 AM
hupp's Avatar
hupp
Where can one find the euro belt tensioner? I currently have the 21" belt installed, but it's a little loose.
Old 09-27-2004 | 11:41 AM
Mark's Avatar
Mark
Replace the viscous, belt-driven fan with an electric (Hayden) fan available from Pep Boys, etc. Gets rid of that belt completely!
Old 09-27-2004 | 11:50 AM
GlenL's Avatar
GlenL
It right next to the hen's tooth.
I've looked and settled for the re-purposed air pump. All bearing, no pump.
Old 09-27-2004 | 11:51 AM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
Ditto
Old 09-27-2004 | 12:13 PM
hacker-pschorr
Administrator
I'm running 4 9" fans on a custom Murph928 bracket. Works great, as long as I'm moving more than 25mph, the fans are not needed. Also tested in 85+ degrees.
Old 09-27-2004 | 01:28 PM
Thaddeus's Avatar
Thaddeus
Deer Slayer
I will plumb my smog pump into the intake plenum somewhere AFTER the MAF sensor. that should make it go fast and run tight, yo.
Thaddeus's Avatar
Thaddeus
Deer Slayer
Then I can say my 928 is supercharged, schweet
Old 09-27-2004 | 11:00 PM
JKelly's Avatar
JKelly
Thanks for the reply's guys. I used a tip from SHRKBIT to take care of it for now....""The air pump or diverter valve started trumpeting, we silenced it by disconnecting and capping the vacuum line to the diverter valve.""
This took about 10 minutes from hood open to hood closed (the quick fix) and seemed to work fine. I used a stainless machine screw of the proper diameter to plug the vacuum line. When I get an afternoon free, I'll completely remove the air (smog) pump. I don't think it will be needed anymore with aftermarket cats. I wouldn't mind to install electric fans either.
Quick Reply: Air pump question....
