928S4 drivetrain vibration
Hey Joe,
A direct bolt in! The stud thread size is different, so you need 4 matching nuts - and a small detail: the #2698 mounts (in my case) measured 76mm high vs. the reported 78mm of OEM. I stuck in two flat washers, but doubt that it was necessary.
Now that you've got the lower A-arm bolts all warmed up (nice job on the Bilstein/Eibachs!), go for the mounts!
Yes, that is definitley one of the next couple of project. I know performance wise my car is "not all it can be" so that also needs to be addressed. Thanks Garth.
