RANT: 928 Electrical Connectors
Originally Posted by John Speake
I can supply quite a few of the pins, sockets, housings, rubber sleeves, for these Bosch connectors.
Each time I had to remove a connector with a spring clip I was very careful using two sharp awls. The spring clip was then removed and never replaced again. In 16 years have never had one come loose including fuel injector connectors. Also from time to time (once every couple of years) I remove the connectors and put them back insuring good contact. Have never had one break. If the spring clips were left on this would be very time consuming and probably wouldn't be done.
Sorry if this offends the Porsche purists.
Dave A.
Are they the normal Bosch 2 pin types ?
