16v Supercharger kit demo at Wichita 928 OC
#61
I would say you can fuel 6 lbs of boost with the addition of a rising rate regulator to ramp the pressure up under boost. Maybe 70- 80 or so psig would get it?
#62
Carl,
You *should* have no trouble if you use a RRR and the stock injectors at 5-6 PSI. The questions I have are- what is the A/F target ratio?, w/ intercooler?, and what is the target RWHP?
I would just run up and we could install, datalog with wideband, and remove the setup on my '84, but I'm afraid it would be a monster pain as I have updated alt and p/s pump which puts me with a late-model crank pulley.
PM'd you on some other stuff too.
Greg
Greg
#63
Developer
Thanks, Greg for volunteering your L-Jet 928 for the Dyno run.
We will install our kit on it this August and post dyno results once we have them.
There are a lot of requests for a DynoJet chart from a L-Jet car like yours.
#65
Here's a dumb question but my 928 has the A/C system and I'd like to take it all out - really dont need it anyhoo - snorks too any HP's from the engine....
Now is your system built to be installed with or without the A/C ?
I have the ugly and very big '85 928S3.... huge plenum and intakes...
Thanks Carl,
Denis
'85 928S3 5.0L / 32V
Thanks Carl,
Denis
#66
Originally Posted by Carl Fausett
Did you know that we now have monthly payment terms thru PayPal?
You can buy your 928M Stage 1 or 2 supercharger kit and pay for it monthly. PayPal says the payment for the Stage 1 kit is $179 a month.
Hope that helps!
Hope that helps!
I could at least sleep in the garage with the supercharger, right?
#67
Ah .."snorks too any HP's from the engine...." only when it is being used plus rolling down the windows at highway speeds causes more aero drag horsepower loss than running the A/c for most cars...
#69
Administrator - "Tyson"
#70
928 Collector
I find horsepower loss so offensive that I totally deleted the ac systems from Godzilla :P .... actually I will be installing it as soon as I have time. Totally worth the power loss.
#71
I enjoy tooling around in a boosted Shark both with and without my wife and kids with the AC on. If it was gone, my wife would not bother even getting in during the summer. I guess I can afford to give up the 10-15 HP. I have had "toys" with removed AC, and we rarely used them when it got above 80-85 degrees-my old 'vette with headers, straight duals and a fiberglass floor was the worst! Don't give up the AC, and I am 99% sure Carl's kit keeps the AC fully functional.
Jim
Jim
#72
If a/c power loss seems like an issue just wire a switch under the accelerator pedal that cuts off the A/c under full throttle.....
#73
Don't a lot of new cars cut off the A/C under WOT? The 986S feels like the A/C shuts off at 3/4 - WOT.
#74
