Test stand for spare engine
Started with mocking up a basic muffler ..... as my neighbors don't like my cars
We do need of course the bellhousing for mounting the starter motor..... so , as common used , engine stand isn't sufficient.
Now i wonder what would be a good test for the engine once AFR is dialed in and timing . ( if it runs at all
)Would half a hour running at 2000 rpm ( if the cooling fans can keep up ) be relevant ? Would that reveal a bad head gasket ? Show us oil pressure problems etc ? Just want to know if that spare engine is "good enough" to be mounted in the car in case of need....just swap engines between rallies and not having the stress of urgent repairs.
In the car is a 310 HP , this spare one is a 300 HP ( cam #'s ) , used in a track car , only thing i see is some porting at the inlets. Further no idea what was done to it. A short test on starter motor (some years ago ) showed me good oil pressure and compression , so this setup now.
I bought that car ( a '90 GT ) in 2009 as he sold it and went racing a Mustang in the Belgian Belcar Championship. Think he needed some more HP.....
Ignition installed , vac manifold, fuel system and electricity. Still to swap the AFR gauge/sensor from the C2 when i see it actualy runs.
In the end more work for just a "test stand" then i assumed... isn't it always so ?
PS in the car i use 2 pumps & filters/regulators but for "no load" test running one set will be enough. ( one set is told to be good for 200 HP )
