928 Forum 1978-1995
Sponsored by: 928 Specialists
Pressure testing intake
Old May 27, 2024 | 11:33 PM
ejy928's Avatar
ejy928
Cruisin'
Default Pressure testing intake
Greetings all,
Quick question....I am doing some intake leak testing using Dwayne's test adapter (Thanks Dwayne). I hear a hiss from somewhere in the center of the manifold/engine. Hard to pinpoint and it does leak down to 0 very quickly. Before it runs down to 0, I also noticed that when removing the dipstick or oil fill cap, pressure releases. My question is...is this normal? Will there be pressure in the crankcase from pressurizing the intake? Thanks much!
-Ed
Old May 28, 2024 | 09:25 AM
Petza914's Avatar
Petza914
An ultrasonic leak detector will help you pinpoint the location for the source of the hissing sound
INFICON 711-202-G1 Whisper...
Amazon Amazon
Old May 28, 2024 | 10:42 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
if your pressurizing the intake note that the MAF boot has a line that goes directly to the crankcase,
this will let the pressure leak out quickly with the dipstick pulled out or the oil fill cap loosened.
Also the brake booster should be removed from your test as you will be pressurizing it instead of applying vacuum.
Old May 28, 2024 | 04:41 PM
ejy928's Avatar
ejy928
Cruisin'
Thanks Stan and Petza914! Now to find the leak!
Old May 28, 2024 | 06:51 PM
Michael Benno's Avatar
Michael Benno
Here is a video of what an air tight intake can be:
