The 928 parts game
#93
Received 1,679 Likes
Originally posted by Tom. M
OK..
Easy one this time...
OK..
#94
Yep,
The amazing folding rear wing....Early 87 S4...supposedly ended somewhere between vin 1385 and 1400 or so....
Rumor has it that the folding wing was used to allow for easy window cleaning, however, the mechanism broke easily and was very expensive to replace..hence the fixed wing thereafter...
Later,
Tom
midlman@rennlist.net
89GT
____________________________________________________________
Later,
Tom
89GT
Originally posted by Andrew Olson
I assume you're talking about the wing here. From an early 87 S4. (I forget when they went to the fixed.)
#95
Range Master
Pepsie Lite
Pepsie Lite
Wing on Viagra........................or is it Cialis.............does it stay up for more than 4 hours at a time?
#96
Yep,
Yep,
Hints:
- there are two of these on your car (picture shows several views of same part)
- it is exterior body color (amazon green in this case)
(ignore the text that reads "shear points")
#98
Originally posted by Old & New
Gosh, Dave, look like window guides?
So, I think I need to give you a BZZZZZZZZZZT.
These come in a left and right flavor.
Perhaps a more fulsome description might change my mind?
#104
Originally posted by Ed Taylor
Drip moulding ends
Drip moulding ends
(PET: Roof Edge Strip End Piece)
The part pictured mysteriously dropped out of my undertray just after IOC 1 in 2000. None missing on my GT. Rich's Amazon GTS was missing none either. No other Amazon sharks in the vicinity. Seems to have been dropped in production and spent 10 years finding its way to the ground...
#105
Re: obscue part?
Aha..the new cam end journal oil hole plugs....replacing the plastic ones that can deform and fall out....
Later,
Tom
Later,
Tom
Try this one.
Try this one.
