928 Forum 1978-1995
Sponsored by: 928 Specialists
Wintertime is not all bad
Old Mar 27, 2024 | 03:41 PM
paalw's Avatar
paalw
Default Wintertime is not all bad
6-7 months of snow and salty roads every year, at least it makes time for maintenance and cleaning. Motor mounts done. Test startup and running warm today on the lift. All vibrations gone, all is good and ready for spring!
Old Mar 27, 2024 | 04:04 PM
BIMMERMIKE's Avatar
BIMMERMIKE
Looks good!
Which motor mounts did you use and were they original ?
Old Mar 27, 2024 | 04:10 PM
paalw's Avatar
paalw
Originally Posted by BIMMERMIKE
Looks good!
Thanks. The ones I took out were Porsche parts. I guess they were the original ones from 95 with 100.000 miles on them. Replaced with Volvo mounts.
Old Mar 28, 2024 | 08:27 AM
mj1pate's Avatar
mj1pate
Which lift were you using? It looks like it has fixed alignment between the right-left halves. Great for safety. But likely difficult to slide a glider in the middle.
Old Mar 28, 2024 | 08:53 AM
Petza914's Avatar
Petza914
Nice work and your car looks fantastic!
Old Mar 28, 2024 | 11:39 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Wow thats a super clean machine,
it looks like you have most if not all of the cosmoline removed,
thats quite a feat.
I was going to suggest that you recoat the front rotor hats and the rotor edges ,with some hi heat gray
same as the rear rotors you have that are E coated.
this will prevent rust and keep the wheel hub package looking clean after its been washed.
Also I would suggest that you lower the RMB tips a bit to add clearance to the PU cover,
otherwise over time the PU cover will deform and may melt on the tips.
NOTE you could also add a few pieces of aluminum duct tape to the PU cover,
no one will see it but it will protect the paint.
Good Luck with the care and feeding of your machine !
Old Mar 29, 2024 | 04:27 AM
928 GT R's Avatar
928 GT R
Delicious!
And YES it looks clean enough to eat off of!
Congratulations and enjoy it in good health when spring arrives.
