89 GT Taillight Problem
Bit of an issue with the taillights. I bought some new bulbs to replace a burnt out taillight bulb on the passenger side. It was originally the left of the two. I replace the bulb and no dice. I did some digging and saw that it's best to replace both bulbs at the same time so I replaced the right one too... no dice. No neither taillight bulb works even if I swap back in the working original bulb to the same housing. All other lights on that taillight work and I did disconnect the battery after swapping in the 2 new ones to reset the bulb controller. I also checked the fuses for the right parking light and backup light. Anyone have any suggestions cause I'm a bit stumped. Also, I sprayed contact cleaner into the housings to get rid of some build-up. Thanks!
PS: tried to upload pictures from phone, getting errors. I'll give it a go when I get home.
My first guess would be if you do not have 12v at the tail lamp, then go the the connector at the lamp controller and see if 12v is coming out to the tail lamp wire.
Note: you can jumper the inbound 12v to the output wire to circumvent the controller, doing this will no longer give you the warning (this is also done when using LED's).
remove the lamp housing from the car,
then remove the bulb holder and remove the bulb.
push the broken wire through the light socket ,
solder the wire to the center of the bulb,
use a small piece of closed cell foam ,
and stuff it into the bottom of the bulb socket, this will hold the bulb against its stop.
install the bulb after you have sprayed deoxit 100 into the bulb socket.
