woodruff key for visco fan
yes I lost the woodruff key the gives the fan pully grabbing ability. does anyone have one? It piece # 6 in the WSM under visco fan.
On a separate note. Is there anyone else out there where absolutely zero goes right with working on these F$*@ing cars.
Switch to another car. You'll find it's ALL the same.
I don't care what your working on, a car, a satalite, a cat motor, a UFO from the plant X, it ain't going to go as planned.
So kick back, crack open a cold beverage of your choice, drink it down, and smile. For today is a good day, cause your alive, and you nuckles are skinned.
If you have to order a new one, the Porsche P/N is: N-012-708-2
Hope this helps.
Scott
Well 3 hours later from waking up I made a new key out of a 15mm bolt head. Seems to be holding up good and the temp is keeping at status quo. I drive city streets for about 20 min and then I took a hwy shot. 5krpms and it was no issue. So now I'm singing again "On the road again".
Actually everything Does go right. in the end. The question is "do you have the patence to get there on your own?" or do you have the cash to let someone else do it for you? - Ruf
