928 Forum 1978-1995
Sponsored by: 928 Specialists
Loose cables in a 1982 US
Old 11-26-2023, 04:35 PM
kacperbeski
kacperbeski's Avatar
Default Loose cables in a 1982 US
Hey guys,
Doing a quick check-up I found these 2 cables loose in the engine bay. She drives ok and I haven’t really noticed any new problems (out of the ordinary ones).
I’ll appreciate any help. Thanks!
Old 11-26-2023, 04:58 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Clearly theres a microswitch near your throttle assembly -not connected-.
Old 11-26-2023, 05:09 PM
Andrew Schauer
Andrew Schauer's Avatar
That could also be for the A/C idle up air valve, which should be bolted to the strut brace. Can you clean up the wires and tell us what colors they are?
Old 11-26-2023, 06:04 PM
kacperbeski
Thank you both.
the wires are black & ‘white’ (more like off-white). Never really used AC so might be the case.
The throttle seem to be connected (from top)
Old 11-26-2023, 06:05 PM
Ladeef
Ladeef's Avatar
that's the idle microswitch, I have mine disconnected too, sometimes solves weird idle issues. I believe when the switch is activated, "no throttle input" the car goes into idle mixture mode. There's one for full throttle as well, I believe it deactivates the AC?
Old 11-26-2023, 06:08 PM
kacperbeski
Oh, interesting. I am still trying to understand where to plug it in. Can’t see a spot for it. Do you maybe have any pictures / guide?
Thanks!
Old 11-26-2023, 06:41 PM
Ladeef
Ladeef's Avatar
Thanks!
Look where the accelerator cable attaches to the throttle body on the drivers side. Under the intake plenum.
I'll try to fin a pic. There's two microswitchs.
Old 11-26-2023, 07:16 PM
Andrew Schauer
From the '82 US wiring diagram, the idle switch has a black wire, and white/black striped wire. The full throttle switch has a black wire, and wire white. As mentioned, they are both on the side of the throttle body, not far apart.
Old 11-27-2023, 02:24 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,311 Likes on 1,286 Posts
OP One switch is above the other, look carefully you will see them .
The AC idle solenoid has a set of one black wire and one brown wire.
Quick Reply: Loose cables in a 1982 US
