Any thoughts here much appreciated.
Other advice i got was if it grinds in Reverse at a stand still the problem is still the clutch or the clutch hydraulics as Reverse does not have a syncronizer ring and needs the clutch to be fully disengaged to not grind. I have this issue when driving the car, depressing the clutch and shifting into reverse from a standstill.
Any thoughts? Please weigh in.
I'm pretty sure Hacker and others have answered this in earlier posts, but pressing the clutch pedal disengages the clutch and disconnects the torque tube and transmission from the flywheel. So with engine idling and in neutral, press in and hold the clutch down, wait a few seconds for the torque tube to spin down, then engage reverse. If there's grinding, that means the torque tube is still turning: the clutch is not disengaging. Your problem is with the clutch mechanism and/or hydraulics.
I have several 5 speed manual 928s. 2 of which still have this issue. One of which has had the transmission pulled. Another of which I believe i got duped into replacing the transmission for big $$$. I didnt know it at the time but replacing the transmission isn't that difficult. and I got burned by a West Palm Beach indie that redid my clutch for $$$ because i trusted his view that it was a clutch issue.
There seems to be a variety of diagnostic tests that can be done outside of the car. So i'm trying to determine these tests for the benefit of 5 speed manual owners as well as myself to be better educated about going in surgically, on a judicious budget, in an informed manner on repairs.
Yes, 1st/Reverse gear grinding is a blend of issues. But some of these issues can be diagnosed for free hence this information/notes compare share. And apparently some repairs can be done inexpensively - a friend gave me one that quieted things down but wasn't the silver bullet. I'm looking for a very precise/mechanical, step by step diagnosis process for the benefit of all. I think once this issue is gone 5 speeds will continue to appreciate in value. .
All thoughts/comments/criticisms welcome - I'll organize things for the benefit of the community.
If you have multiple 5-speed 928's (like I do). Do what I did 20 years ago. Get a used lower bellhousing (they are cheap) and cut a huge hole in it. Now on the lift someone can work the clutch and someone else can see what is going on.
This has saved me from countless frustrating days.
I curse Porsche for not doing this from day one. For how well engineered this car is, complete and total fail not having an inspection / adjustment method. My fab shop is currently making me another one with a removable plate, if this works I'm doing all 4 cars.
Gentlemen: I've summarized the comments above.
Please comment, critique, add as we're getting close to resolving this very common issue.
The clutch is not releasing and is causing the "gears grinding (only) in 1st and Reverse
As only reverse and 1st grind, and as reverse does not have a synchro, the clutch is not fully releasing, disengaging or is dragging. This is evidenced by the fact that reverse has no synchro.
Pressing the clutch pedal disengages the clutch and disconnects the torque tube and transmission from the flywheel. So with engine idling and in neutral, if I press in and hold the clutch down, wait a few seconds for the torque tube to spin down, then engage reverse. If there's grinding, that means the torque tube is still turning: the clutch is not disengaging. Therefore the problem is with the clutch mechanism and/or hydraulics.
Any single part in the clutch system could be causing the clutch to not fully disengage.
Hydraulics
there doesn't have to be a leak for the master and or slave to not be fully functional
Intermediate disc not holding adjustment
Clutch disk has failed to a point where it's frayed and continues to rub even when disengaged
Release bearing failure
Pressure Plate failure
Lack of proper lube
Clutch shaft is damaged
Upper ball / cup issue
Improperly bled
There is no hydraulic "adjustment" on 928s. Instead there is a hole in the bottom of the bellhousing that allows you to see if the slave rod is moving the full distance. The slave rod is probably not moving the full distance.
If not the slave rod, then it could be the slave, master, the line connecting them (or all three) have air in the system.
Or it could be the intermediate disc. The intermediate disk has three adjustment tabs on them to "center" the disc between the two friction discs. There is some debate on how to do this, I cheat: https://rennlist.com/forums/928-foru...ch-owners.html When those three adjusters wear out, that center "disc" floats back and forth causing the clutch to drag. One solution (which I did on my 79) is replace the rivets: https://rennlist.com/forums/928-foru...l#post18924701
Or it could be something as simple as the hose that connects the slave / master was installed incorrectly and has a low spot preventing that one last air bubble to burp out.
Or it could be:
The clutch master had failed
One of the clutch discs is badly frayed
Release bearing housing is physically broken
Proper grease on the shaft (it was dry as a bone & pitted) - must use proper grease here
This makes adjusting the clutch super easy: Solution: Get another bell housing and cut an access / viewing window in it.
Mount the clutch slave cylinder to the lower bell housing unit with the access/viewing window.
Put the car on the lift and have one of your guys run the car through the gears as we watched from below to see what is going on. While the intermediate plate can be adjusted with the housing off and without operating the clutch, being able to operate the clutch AND tweek the adjustment at the same time could be very helpful.
Gentlemen:
One diagnosis / fix that came back on my 1979 5 speed grinding in 1st and Reverse was a Shift Collar + 1st gear set replacement.
Any thoughts/views much appreciated.
What kind of wear do you have on the gear that warrants replacement? Bad dog teeth wear? Pics would be worth many words. Precision Motorwerks has remanufactured dog teeth, though I'm not sure for early gear sets.
Shift collar and 1st gear synchro replacement to fix gears grinding in 1st and Rev
The blue arrow is the shift collar that was sliding. Please let me know your thoughts on the gear teeth. I've been burned before on this issue and I get a number of differing diagnosis anywhere from something in the clutch to i need a rebuilt transmission.
