Rebuilding Seats
Rebuilding Seats
Word on the street here on rennlist is that the 928 group is the best source for seat rebuilding information.
I am hoping to glean some of this knowledge and apply it to the rebuilding of my seats destined for a special project. I have a pair of power sliders that I have harvested from donor seats. There are a number of plastic wear items/washers that are part of the screw drives that take up slack and minimize free play in the assembly. See pictures below.
Plastic/rubber cover surrounding the thrust washer is present on the 'newer' donor seat rail. Pardon the debris...it will be cleaned and lubricated prior to reassembly.
Older donor rail with degraded/destroyed plastic/rubber cover showing the metal thrust washer. Is there a source for these items?
End of the screw drive on a the newer donor. Note the cup washer and what appears to be some sort of shaft centering guide washer held in place with a circ clip. Is there a source for either of these items, or has someone taken the initiative to produce these from a hard plastic (UHMW?) material or 3D printed them??
Thanks for looking.
Thanks for looking.
Jay,
There is a chap who flogs these kits on Ebay that appear to be 3D printed - a few folks on this list have used them. Do a search in Ebay using "Porsche seat repair kit" as the search criteria. It is the same system as used on 944 and 911 seats and costs around $40 or so as I recall. I have never used them personally.
I sorted this problem out on my 928 seats by using copper washers. I had a pile of them of different thickness's sized for spark plugs but never used them for intended use so re-purposed them.
Jay Wellwood (11-20-2023)
If you are going to repair the seat adjusters, here are a couple of forum posts you should review that detail the process as well as links to inexpensive components you can source yourself:
https://rennlist.com/forums/928-foru...ir-thread.html
https://rennlist.com/forums/928-foru...ix-how-to.html
All the best-
