928 Forum 1978-1995
Sponsored by: 928 Specialists
WTT 3.09 Differential for ...
Old 10-19-2023, 12:07 AM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Default WTT 3.09 Differential for ...
At some point this winter I'm dropping the drivetrain of my five speed GTS. It has 3.09 rear end. Great for AX not so great otherwise.
I am looking for a compatible 2.73 ratio.
Not in a particular rush.
Kevin
Old 10-19-2023, 12:29 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,604 Likes on 1,258 Posts
Is your GTS a 5-speed or an automatic?
Old 10-19-2023, 01:47 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,469 Likes on 1,465 Posts
Buy a new GTS ring and pinion, from Porsche.
Fairly economical.
Install.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 10-19-2023, 02:52 AM
jcorenman
jcorenman's Avatar
I don't know anything about 928 A/T's but if you want a 2.20 then Greg is right, Porsche's price is a steal.
I did somehow wind up with a 2.54
ring & pinion for an A/T diff which I would be happy to part with, if that is of any interest.
Old 10-19-2023, 08:58 AM
Kevin in Atlanta
Five speed.
Old 10-19-2023, 11:39 AM
Gary Knox
Gary Knox's Avatar
Kevin,
I had a 2.54 diff in my '89 S4 manual trans track car (and also in '94 and '95 automatics). I really like it. Much better than the 2.20 I've had in various S4's, and I like the slightly lower cruising RPM's better than the 2.73 in friends GT's I've ridden long distances in. Just my experience.
Gary
Old 10-19-2023, 11:46 AM
Kevin in Atlanta
Originally Posted by Gary Knox
Kevin,
Gary
Me too. I have it in my 87 five speed.
Back in the day Walt Konecy (sp) replaced his 90 GT's Diff with a 2.2.
Old 10-19-2023, 12:19 PM
Cheburator
Cheburator's Avatar
Kevin,
Gary
Are you sure it's not the Euro/RoW 2.64:1 diff and not 2.54? I have not heard anyone being able to swap an Auto final drive in a 5spd box...
I have a spare G28.55 with a damaged crown - PSD fluid leaked inside the box - and have been meaning to see if a GTS final drive can be made to fit inside the GT box. If not, I still need a spare GTS final drive - they aren't getting cheaper or more available and then I would swap an S4 G28.13 RoW final drive in the G28.55 and keep it as a second spare alongside my good G28.55. Yes, I know, having two G28.55 side by side is pure greed...
Old 10-19-2023, 01:23 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Originally Posted by Kevin in Atlanta
Five speed.
That sucks..I was on the verge of a swap where your trans, and my trans..end up at Greg's...
Old 10-19-2023, 01:43 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
To remove any confusion, 5 speed ring and pinions are not remotely similar to automatic ring and pinions.
Old 10-19-2023, 01:56 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
GT and GTS ring and pinions are interchangeable, with the exception that you need a 5th gear to match whichever one you choose.
I've installed several GTS ring and pinions (with GTS 5th gears) into GT transmissions. Buying both the ring and pinion, along with the 5th gear is more economical than buying just the GT ring and pinion!
BTW: The latest GTS ring and pinions are also of very high quality, built on modern CNC gear machinery, and are amazingly quiet. Significantly reduced backlash specifications.
HUGE change from a GT or early GTS ring and pinion. "Night and day" type of difference.
Cheburator (10-19-2023)
Old 10-19-2023, 07:06 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
We have 928-302-911-56 new in stock $695
https://shop.928intl.com/Ring-And-Pi...02%2D911%2D56/
Old 10-20-2023, 01:01 AM
The Forgotten On
The Forgotten On's Avatar
Do new auto ring and pinions benefit from this as well or are they still old tech that have been sitting on a shelf for 30+ years?
Old 10-20-2023, 01:40 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Not sure.
I've never needed to buy a new automatic ring and pinion, from any model year or ratio.
Thinking about that, I've done plenty of high mileage automatics, so the ring and pinions must be very durable.
Old 10-20-2023, 02:36 PM
SwayBar
SwayBar's Avatar
I've got two, too, and my spare has 18k miles on it.
I wouldn't consider it greed, it's just planning ahead.
The following 3 users liked this post by SwayBar:
Cheburator (10-23-2023), hwyengr (10-20-2023), Speedtoys (10-20-2023)
Quick Reply: WTT 3.09 Differential for ...
