R and R 1980 Flywheel
12 mm XZN socket on an impact gun, zip that bugger right off. For torquing get a long threaded M8 bolt and run it through one of the PP mounting bolt holes so it sticks into one of the engine block web castings as a 'hold'.
The following 2 users liked this post by Rob Edwards:
davek9 (08-15-2023),
Kevin in Atlanta (08-10-2023)
I have the correct XZN sockets and Ryobi 1/2" impact gun. The TT is already moved back.
Thanks!
pilot bearing needs to be replaced its got rust
NOTE to hold the flywheel,
make a metal strap,
a hole in either end
bolt one end to the flywheel pp hole ,
then the other to the starter bracket.
make a metal strap,
did you replace the pilot bearing?
odds are good if you didnt then it will have a short service life.
As its been subject to corrosion and then cleaning fluid,
this will wash the grease out of the bearing as well as wash rust into the bearing.
The pilot bearing is perfect. I did not wash it out. I compared it to new ones I have. Identical feel. Spins smoothly.
Kevin
