Very First 928 Test Drive
I cannot imagine 60+psi in the rear.
The shop said high pressure originally sets the bead and it's easier to move car around the shop, makes sense, tire pressure reset was forgotten since I showed up earlier than expected to pick up.
Our GT is a real GT and not a VW Golf with a GT stick on the trunk! IMHO There is no such thing as a Golf GT, it's simply marketing BS.
Allow me to quote my good friend Roger: "Schocki, as soon as you hit the triple digits and above, you'll enter a world of your own".
This quote sums it all up in one single sentence. Next time, get into a well maintained 928 and remind yourself when and for what reason this car was designed. Forget about whatever you drove to go to your test drive. Sit down and remind yourself, that this machine wants positive and direct inputs. With this in your mind, it'll be a much more enjoyable drive. Make sure that you hit the triple digits, and you'll understand...
They are firm but not harsh - they feel perfect for a Sport/GT car on the street, and are half the price of the Boge Sports.
I'm reporting back, the car drives completely different with 36f,36r, took my normal ride home, left and right sweepers posted 55 mph at 80 mph and she felt good, I'm going to have a local Rennsport shop look at the suspension and give me their opinion.
Adamant, 15k vs how many miles on your old 87? I do think the suspension can feel better, I know it's 37 years old rubber wears as do the shocks.
Entire suspension right now, is OE and <2yrs old.
Once the car gets much below that height, the car is riding on or very close to the bump stops and the "stock" suspension pieces need some "help", in order to get the shock away from the bump stop. (We've got "ultra high performance" pieces which allow the cars to be set to below 100mm.)
By 145mm, the choice of shocks is somewhat moot, as the bump stop becomes the primary shock absorber, in compression. (Unless stock pieces are modified.)
Rebound is still a factor, but the force of the "rebound" needs to include the force that the bump stop exerts. (So if the shocks are very soft, they not only will not be able to control the unsprung weight but probably can't even keep up with the bump stop.)
Unfortunately, there are many 928's sitting way too low, ruining the handling of these cars.
"Good looks" and "good handling/good ride quality" are very often an oxymoron in a stock 928....
The other thing to be aware of is that I'm "discarding" shock dyno results from shocks that are extreme "outliers"....shocks which I consider to be bad, right out of the box. (Not an issue in higher quality shocks.)
"Compression" in a Koni and a stock Boge (now F&S) are very close to being the same. Note that no amount of "adjusting" the Koni will change the compression numbers, unless the shocks have externally adjustable compression (expensive to have done.)
"Rebound" in a Koni at full soft is very close to the numbers of a stock Boge (F&S) at .5in/sec.
The force numbers stay very close to each other, up to about 2.5in/sec.
By 5.0in/sec, the stock Boge has about 75 pounds more force than a Koni at full soft.
By 9.0in/sec, the stock Boge still has about 300 pounds more force than a Koni at full soft.
What does that mean?
In normal driving conditions and in steady state corners (no bumps), a Koni at full soft and a stock Boge are very much the same.
However, at higher shock travel speeds, the Koni, at full soft starts to lag behind the stock Boge. The Koni, set to this stiffness, will be loosing the ability to control the unsprung weight.
At the upper limits of shock travel speeds, the Koni will no longer be able to control the weight of the unsprung weight. The bump stops, in the car, will be the controlling factor.
In short, someone buying shocks would generally be better buying the stock "off the shelf" Boge/F&S shock versus buying a Koni set and setting it at full soft.
However, the issue with stock Boge/F&S shocks has been consistency. The shocks we have tested were like "fingerprints"....no two the same.
These shocks probably need to be dynoed and then return/discard/sell on the internet the "lame ones".
As I mentioned before, Konis also tend to be a little "fingerprinty", especially in the lower "force numbers" once the shock are adjusted towards the stiffer side.
(Not very handy to have two front shocks off by 100 pounds of force at slower piston speeds....it's like having one shock which works and one which is completely worn out.)
Bilstein and Boge Sports usually have much better consistency, which is why we tend to use these brands.
Car sits on factory springs but is set to the minimum factory height when delivered in 1992 (not the minimum permissible height of a sagged suspension).
I do my own suspension setup with self-fabricated laser tools, tangent calculation and turn tables for the wheels. Suspension height was adjusted with a full tank and my weight in the driver's seat.
Takes a couple of tries to get it right, but it's certainly worth it. After the height is correct and has settled, it's time to get the suspension angles into spec.
After all the work is done correctly, the car drives like a GT.
Most 928 sit way too low and people don't like the looks of a properly setup stock suspension. They have no idea what they're missing.
Another factor are tires. Yes, even in Germany you can drive any brand of tire. They just need to have the correct speed rating and load index. IMHO, the only way on how to get the correct driving experience is to go with Porsche recommended "N" specification tires. They are different, especially the tire side wall is a lot stronger with N tires.
When people ask me in the German forum about my tire choice: Michelin Pilot Sport N3. Great tire, with great grip and overall performance.
