Very iffy fuel pipe
Very iffy fuel pipe
On a bit of an inspection this morning, spotted this...
That's the fuel pipes at the rear. The sad looking rubber pipe is bending around the front of the rear subframe.
Apart from it obviously needs replaced, the whole thing looks unlikely. The rubber pipe runs all round the top of the wheelarch and ends up at a similar looking fitting at the top-rear of the wheel arch. There are lots of cable ties involved.
Is this correct or some sort of bodge? It certainly doesn't seem a good idea to have that sharp bend around the subframe.
Any pointers as to how it should be done are appreciated. And... if that rubber hose is right, does anybody know what bore size it is so I can order some new?
Those fittings typically have a barbed connection about 1 inch lon and I would think that DIY bodge is kinked over the end of the barb.
If the routing is stock for that model year then one imagines Porsche would deploy a pre-formed hose able to make a tighter bend radius whereas a DIY amateur would probably use a straight hose of some kind with a larger bending radius than space available dictates.
Unfortunately I am not familiar with the layout on your model not that I would expect it to be much different to mine. Is that on the fuel feed line or the fuel return line? Either way running like that is not realistic and you need to rain the system and get the detrius out. If that section is like that what condition is the rest of the fuel plumbing system like? No idea what size that hose is and doubtless someone will know but you can cut the hose and measure it. I understand all fuel hoses are based on imperial sizes like 5/16th inch or whatever but I could be wrong on that one.
It's 9.5mm (it says so on it) and it's badly perished along its length - so I'll need to figure something out.
As you say... the rest of it doesn't look amazing so I'll check it all carefully.
SAE J30R9 will be the applicable spec
I happened to be under my 86.5 and snapped these pics. (I'm not positive the angle of your pic, but one of these should be it) There are a couple of tight 90 degree turns.
Anyway there are nothing but metal lines in that area on my car, and certainly nothing like what you have. I suspect the previous owner had a rubber line fail and he took it off, removed the factory metal-to-rubber "crimp" clamp and slid some hose and clamp on the remaining barbed hose connection.
And yes, 3/8th inch high pressure fuel hose will work, and should be less likely to kink. Use a fuel injection clamp (the solid metal kind, not the universal clamp you have now.
thepurpleblob (06-17-2023)
Not sure what's going on. It's clearly been replaced at some point - hard to know what was there before. The rubber pipe is properly cracked and degraded.
I've ordered some more injection hose (it's the pipe that comes from the pump) and will figure something a bit more sensible out.
They are not called "Imperial" units because they were made in China!
If the original spec was metric ze Germans would have sized it at 10mm not 9.5mm! Same for ac system fittings by the way. I like the US system of referring to them as a number of 1/16ths- thus 3/8th is 6AN.
A lot of the vendors here describe it as "10mm Injection hose" and then in the spec says "9.5mm ID". Sigh....
Former Vendor
We make new fuel lines, for restorations and repairs, in our shop, on a frequent basis.
They are, indeed, 10mm.
On the other hand if you really want to get confused when it comes to tubing systems 9mm tube has an OD of - you guessed it- 9.5mm. 3/8th tube has an OD of- 9.5mm! Needless to say the fittings and the tubing size are not one and the same thing.
In the oil industry we had to be very careful when it came to impulse tubing systems [the kind of stuff we use to carry the process conditions from piping into instrumentation]- metric sizes and imperial sizes were very similar and the threaded connections looked more or less identical but they were not- one having a thread angle of 60 degrees and the other 55 degrees- try eyeballing the difference between those two! Get a mix of components and it could potentially be disastrous.
I'm more than happy to run new (kunifer) pipes up and down the car. In fact, it's probably looking like a very good idea.
The thing I struggle with is figuring out what the correct connectors need to be on the ends. Anybody knows, or any advice on working it out, much appreciated.
EDIT:
From my limited research it looks like 10mm compression to AN6 (possibly AN8) fittings are the answer. Some measuring / sanity checking on the car next.
EDIT:
Basic Sponsor
