928 Forum 1978-1995
Sponsored by: 928 Specialists
CLUNK Clunk clunk noise.. help
Old 06-10-2023 | 07:05 PM
FredR's Avatar
FredR
Todd,
What speed were you doing when you shot the video - I am guesing 30 mph?
16 inch wheels/tyre size?
Rgds
Fred
Old 06-10-2023 | 07:06 PM
Todd Gibbs's Avatar
Todd Gibbs
Originally Posted by FredR
Todd,
My effort with the half shafts suggest that one cannot really tell the condition of the CV joint whilst it is in situ but that may reflect the limits of my capabilities. On the other hand when you have the shaft in your hands it is very easy to feel whether there is any radial play. To get them out [if you feel such is warranted] you need a 3/4 inch socket set and a big lever arm- that or a very powerful impact gun.
Replacing the boots and cleaning out/changing the grease is a once in every "10 year job" as I am concerned and given your 928's background or what I understand of it such action would seem prudent no matter the actual cause of your perceived issue.
Rgds
Fred
Thanks Fred, I think I'll put the half shafts on my "soon to do" list, assuming I locate this clunk, if not I'll do them as part of the investigation!
Todd.
Old 06-10-2023 | 07:07 PM
Todd Gibbs's Avatar
Todd Gibbs
Todd,
Rgds
Fred
About 30, 15" wheels.
The camera bounces because its a heavy camera on a cheap suction mount.
Todd.
Old 06-10-2023 | 07:09 PM
Todd Gibbs's Avatar
Todd Gibbs
Originally Posted by h2pmr
hi Todd
noises and vibrations etc can be a real pain to find, i try to reproduce things like this when the vehicle is stationary, need a 4 post lift to keep the vehicle on all 4 wheels, then get someone else to bounce the body up and down while the vehicle is up on the lift and you are underneath, if you still cannot hear anything try holding components, shock absorbers etc to see if you can "feel" the noise with your hand.
could also try getting someone else to drive it on a private road while you sit in the tailgate area with the tailgate carpet removed to see if you can pinpoint the noise.
if it does it at slow speeds open the tailgate while its being driven, the more you can pinpoint its location, the number of things it could be decreases.
good luck
Phil
Hi Phil,
I have the car up on ramps and have been bouncing / pulling it around, no noises. That makes me think its something in the unsprung mass area (ie, wheels, hubs, etc) rather than on the vehicle itself. I need to get in the back while someone drives...
Thanks!
Old 06-10-2023 | 07:10 PM
Todd Gibbs's Avatar
Todd Gibbs
Originally Posted by Rob Edwards
Speed-dependent knocking like that that goes away with the brake pedal sounds to me like a bad CV joint that's knocking when loaded in one direction and then the joint gets loaded in the opposite direction (and stops knocking) under braking. Or a bad wheel bearing (? Though that should vary with turning left or tight/varying axial load..). Are the CV boots intact? And the CV joint bolts are all tight to at least 60 ft-lbs to the transmission output shafts?
Hi Rob,
CV boots all look good. But your logic sounds good to me regarding the CV joints. Bearings all seem ok. Will keep searching but its getting closer to me pulling the half shafts off...
Thanks!
Old 06-10-2023 | 07:11 PM
FredR's Avatar
FredR
What size/profile are the rear 15 inch tyres?
Not to worry- assuming they stuck to the plus one sizing concept even in those days you probably have 215x60x15 rubber to give a rolling diameter of 25 inches thus a circumference of 6.5 feet. At 30 mph or 44 ft/sec that means the wheels would be rotating at 6.7 revs per second. Using my somewhat dilapidated flute playing skills I can resolve in my head up to 8 beats per second very accurately and up to 16 beats per second pretty roughly.
Listening carefully to your video tape a few times I reckon the vibration beats are coming at something less than 8 beats per second.
That suggests to me that in all probability what you are hearing is half shaft speed related.
Old 06-10-2023 | 07:50 PM
khalloudy's Avatar
khalloudy
I think getting a set of chassis ears is a good investment in tracing noises.
Could be worn shocks, loose exhaust system (check that you have all your rubber hangers are there). Half shafts is an easy diagnostics (just have someone look at the shafts as you engage from P to D to see a movement mated with a clunk - should be zero.. any rotation and sound is a quick telltale).
Old 06-10-2023 | 08:50 PM
Todd Gibbs's Avatar
Todd Gibbs
Hey Khalloudy, thanks for that - will test the half shafts/CV joints tomorrow. Exhaust is solid, I just rebuilt the entire thing
Old 06-10-2023 | 09:23 PM
gbgastowers's Avatar
gbgastowers
From: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
Check these. I had one break and it really was clunky
Old 06-10-2023 | 10:26 PM
SwayBar's Avatar
SwayBar
I have been trying to solve the same problem for over a year, and finally solved it 2 days ago. Thunk thunk over big bumps.
Long story short - the driver-side exhaust pipe was hitting the cutout in the crossmember.
And I discovered it by wiggling the tailpipe side-to-side versus up-and-down like I had been doing.
Now that I have it diagnosed, not sure yet how to fix it.
Old 06-11-2023 | 04:59 AM
Todd Gibbs's Avatar
Todd Gibbs
Hey Swaybar, good find! unfortunately I know that isn't my problem. I have completely rebuilt the exhaust system... (final video here
Old 06-11-2023 | 05:00 AM
Todd Gibbs's Avatar
Todd Gibbs
Hey, the side what is knocking seems ok, I'll double check both though today. Thanks!
Old 06-11-2023 | 05:32 AM
jheis's Avatar
jheis
On my '89 it was more of a Whump, whump, whump noise. At first I also thought maybe it was a broken exhaust hanger, allowing the exhaust to move around, but the exhaust checked out fine. From the driver's seat it sounded like it was coming from the passenger's side. From the passenger's seat it sounded like it was coming from the driver's side..
Turned out to be a bad rear wheel bearing. Took driving by a mechanic standing outside of the car to pinpoint the problem.
Old 06-11-2023 | 07:52 AM
Todd Gibbs's Avatar
Todd Gibbs
Update:
So it wasnt the heat shield.
But on my driveway, put in D and let it creep forward... tapping brake pedal and I hear the clunk, tap brake on/off/on/off etc and I hear clunk cluck clunk. Its defintely directly related to the driver-side rear hub.
Could it be the floating calliper clunking around? apply pressure and it all tightens up? Could it still be the CV Joint?
Out on the road it is never a single clunk, its always CLUNK Clunk clunk (each quieter that the first, like something vibrating/shaking a few times but less each time)
Does that help narrow it down?
Todd.
Old 06-11-2023 | 08:09 AM
FredR's Avatar
FredR
For purposes of clarity- are you saying you hear three clunks and the noise decays and is gone or is it more a continuous clunk that is somewhat cyclic noise wise [as best I could understand from listening to the video clip]?
Quick Reply: CLUNK Clunk clunk noise.. help
