Need Help Identifying part
Those look like remnants of a PO audio/security install. They don't appear to be factory items.
I would check the circuits they are connected to and remove if possible.
Do you have an aftermarket alarm or stereo?
HTH,
Scott
HTH,
Scott
Yes there is an aftermarket alarm. there is a picture of the sensors in this thread
https://rennlist.com/forums/showthre...hreadid=130808
Well, That is my gremlin. I started the car and unplugged the big relay and it died. Same symptoms as the problem it will start when turned over then die when you release the key. I followed the wires back and they had tapped the wire that powers the coil.
A very *interesting* way to do starter interrupt. BTW, that method is extremely amateurish..... Proceed with caution on all other things electrical as there may be more gremlins lurking.
What about the second relay? What is its function?
Good luck
Good luck
Ideally, I think you would be best off following all non-original wires end-to-end, restore everything to original as best you can make out, then begin troubleshooting from there. I have much higher resolution versions of all the pics I took... if you see any of those on my site that would be helpful to you, let me know which & I'll post.
Thanks for the offer. The large relay breaks the current to the coil. The little relay switches the big one on and off. I found where they spliced (cut in two) the wire that runs from the key through the fuse box to the coil and reconnected it like it was when it left the factory
